Navigating engineering and technology work environments
As an engineer or technologist, your role may require you to work in a range of different environments, and where you are may change from day to day. This unfamiliarity can add an additional level of anxiety for someone who is disabled.
Some environments you may encounter include the following:
- Office spaces
- Hybrid and remote environments
- On-site locations
- Laboratories and technical floors
- External travel
Here are a few tips on anticipating the unexpected and safely navigating through these environments.
Create and share a ‘guide to me’
Put together a document that explains the type of challenges you tend to experience at work, and include what helps overcome or reduce these. Although this may take some time to create, it can be used again and again to easily share your requirements with others, removing the need to continually repeat or explain yourself to new colleagues.
Read accessibility information before you go
Some organisations may have an accessibility guide already available, but even if they don’t, they are required to make reasonable adjustments to help enable you to carry out the job. If accessibility information isn’t readily available, you can reach out to the facilities or HR team to request this.
Ask AI to identify potential challenges on your route
Adding the details of your planned route, along with information about your physical requirements, into an AI search engine can help give you an insight into barriers you may encounter, so you can better plan to manage them.
Key built environment considerations
Engineering and technology environments can be varied, and sometimes unpredictable. As a result, there could be a range of key accessibility considerations that apply in your workplace, which may differ from day to day.
Here is an overview of some key considerations to make when planning and designing a space that you want to work for colleagues with differing needs.
Physical accessibility
- Is there step-free access throughout the building, including entrances, circulation routes and emergency exits?
- Are there accessible parking and drop-off points located close to entrances?
- Does the building have automatic or easy-to-operate doors?
- Are there accessible toilets and changing facilities available and working correctly?
- Are there height-adjustable desks and workstations?
- Are the meeting rooms accessible? Could they unintentionally exclude someone?
- Are there working lifts that are easy to locate and use, with tactile buttons and audible announcements?
- Are the foot-traffic routes clear and obstacle-free?
Sensory accessibility
- Adjustable lighting where possible.
- Reduction of glare and flicker from lighting.
- Quiet workspaces and concentration areas.
- Acoustic treatment to reduce background noise and echo.
- Spaces that allow individuals to control their environment where possible, for example, temperature controls.
- Use of calming colour schemes and avoidance of visually overwhelming patterns.
This aligns strongly with the approaches described by AtkinsRéalis below in relation to quiet workspaces, adjustable lighting, welfare rooms and biophilic design.
Neuroinclusive design
- Varied work settings to accommodate different working styles.
- Quiet rooms or low-stimulation environments.
- Clearly defined spaces for collaboration and focused work.
- Consistent layouts and clear wayfinding.
- Predictable environments that minimise unnecessary uncertainty.
- Spaces for decompression or sensory regulation.
Wayfinding and navigation
- Consistent signage throughout the building.
- Good colour contrast on signs and wayfinding systems.
- Tactile and accessible navigation information where appropriate.
- Clear landmarks and visual cues.
- Logical layouts that reduce cognitive load.
Welfare and wellbeing
- Multi-purpose welfare rooms.
- Prayer and reflection spaces.
- Rest and recovery spaces.
- Spaces that support people with long-term health conditions, fatigue, chronic pain or hidden disabilities.
Digital and hybrid accessibility
Increasingly, the workplace extends beyond the physical building.
- Accessible room booking systems.
- Hearing loop technology.
- High-quality video conferencing facilities.
- Accessible digital signage.
- Consistent accessibility standards across workplace technology.
