Knowing your rights
Your rights as a disabled employee
A person is defined as disabled if they have a physical or mental impairment that has a substantial and long-term adverse effect on their ability to carry out normal day-to-day activities (Section 6 of the Equality Act 2010).
Under the Equality Act 2010, it is unlawful for an employer to discriminate against an employee because of disability. This protection applies at every stage of employment, from recruitment and interview to promotion and dismissal. It also extends to self-employed people who are hired to carry out work personally, rather than running their own independent business.
Your obligations as an employer
Employers have duties, including:
  • Not discriminating against disabled employees or job applicants because of their disability, or treating them unfavourably because of something arising from their disability.
  • Taking all reasonable steps to prevent disability discrimination and harassment in the workplace.
  • Making reasonable adjustments where they know, or could reasonably be expected to know, that an employee is disabled and is likely to be put at a substantial disadvantage compared with people who are not disabled.
If I'm disabled, do I have to declare my disability to my employer?
No, you are not legally required to declare your disability if you would prefer not to do so. However, it is important to note that your employer only has to make reasonable adjustments if they know, or could reasonably be expected to know, that you are disabled and are likely to be put at a substantial disadvantage compared with people who are not disabled.
During the recruitment process, employers can only ask health-related questions for the following reasons:
  • To find out whether you can participate in an assessment, such as an interview or test, or whether they need to make reasonable adjustments so you can do so.
  • To determine whether you are able to carry out a function that is essential to the role.
  • To monitor the diversity of applicants.
  • To take positive action to support disabled applicants, as allowed by Section 158 of the Equality Act 2010.
  • If the role genuinely requires the person to have a particular disability, to find out whether you have that disability.
Any health and disability-related information that you disclose must be handled sensitively by the collector, stored confidentially and only kept for as long as the information is needed.
Reasonable adjustments
Employers are legally required to make reasonable adjustments for an employee when they know, or could reasonably be expected to know, that the employee is disabled and is likely to be put at a substantial disadvantage at work because of their disability.
Reasonable adjustments are changes an employer makes to remove or reduce the disadvantage an individual experiences because of their disability. The necessary reasonable adjustments will be unique to each individual; however, some examples include:
  • Flexible working hours or locations.
  • Assistive technology, including mobility aids such as wheelchairs and walkers, sensory tools such as hearing aids and screen readers, and communication devices such as speech-generating apps and specialised keyboards.
  • Adaptations to communication methods, for example talking instead of typing, or providing information in accessible formats such as Braille or audio.
If an employer is aware, or reasonably should be aware, that an employee is disabled and likely to be put at a substantial disadvantage compared with people who are not disabled, the employer must make reasonable adjustments. This applies whether or not the employee has requested an adjustment. If they do ask, an employer must make the change if it is reasonable to do so.
What's 'reasonable'?
It can be difficult or uncomfortable to understand what is considered reasonable to employers, especially when discussing something as personal as disability.
Guidance from ACAS states that an adjustment may be reasonable if it meets the following criteria:
  • It will remove or reduce the disadvantage experienced by the individual at work.
  • It is practical to make.
  • It is affordable.
  • It will not harm the health and safety of other employees.
If you have requested an adjustment that is deemed unreasonable by your employer, they should still try to find an alternative option that helps you carry out your role. This could involve making other adjustments that are reasonable.
What about the access to work scheme?
Access to Work is a government-funded support scheme that helps disabled people get into work and remain there.
Access to Work may contribute to the additional employment costs resulting from a disability or health condition that the employer would not normally be expected to cover as part of its duty to make reasonable adjustments. This can include communication support in interviews, special aids and equipment in the workplace, adaptations to equipment and vehicles, help with travel costs, and the provision of support workers and mental health support services.
Access to Work can be applied for online via GOV.UK through the "Apply for an Access to Work grant" service.
It is important to note that the Access to Work scheme is undergoing changes that may impact who is eligible to receive funding and may increase the responsibility on employers to support their disabled employees. Information on the current eligibility criteria can be found through GOV.UK's Access to Work guidance.
Recognising disability discrimination
Under the Equality Act 2010, it is unlawful for an employer to:
  • Treat a job applicant or employee less favourably than others because of disability.
  • Discriminate indirectly by applying a practice, policy or rule that applies to everyone but puts a job applicant or employee at a disadvantage because of their disability.
  • Discriminate by treating a disabled job applicant or employee unfavourably because of something that results from their disability, rather than because of the disability itself.
  • Fail to comply with its duty to make reasonable adjustments where a disabled job applicant or employee is placed at a substantial disadvantage.
  • Subject a job applicant or employee to harassment related to disability.
  • Victimise a job applicant or employee because they made, or intend to make, a disability discrimination complaint under the Equality Act 2010, or because they have done, or intend to do, other things in connection with the Equality Act 2010.
More detailed guidance is available from ACAS through its disability discrimination guidance.
If you believe you have suffered disability discrimination at work, your next course of action would normally be to speak to your employer and see whether the issue can be resolved informally. For example, it may be appropriate to arrange a meeting with your line manager to discuss what has happened and explain your perspective on the matter.
If you decide to formally raise a grievance under your employer's grievance procedure, you will normally be asked to meet with your line manager or another appropriate person who is investigating the grievance. You will also usually have the right to be accompanied at the meeting by either a colleague or a trade union representative.
Further information about resolving workplace disputes can be found through GOV.UK's workplace dispute guidance.
If the issue cannot be resolved internally, advice and guidance on next steps, eligibility for legal support and how to access it are available through GOV.UK's legal advice and information services.
