Topic Title: Today's teaser
Topic Summary: "Green" hand drying
Created On: 05 September 2012 12:43 PM
perspicacious
A lot of toilet hand dryers are promoted on their environmental "benefits" when compared to the paper alternative and most are proximity sensed.
Today's teaser: If left in its dormant state for a year, how many minutes/hours of hand drying would you get if you replaced it with a manual push button type?
BOD
 05 September 2012 12:48 PM
stateit
Dyson airblade claims a standby energy consumption of 1W.
So go figure...
S George
http://www.sg-electrical.com
 05 September 2012 12:53 PM
perspicacious
I have done the maths on a typical, rather than seldom seen, type and the figures are surprising, mindful of the topic summary......
BOD
 05 September 2012 03:25 PM
Ricicle
With a 1w standby on a sensor dryer, I make it equate to approx. 45 secs. drying time per day on a manual dryer of 2kw.
And that's without any drying energy from the sensor dryer !
 05 September 2012 03:34 PM
impvan
In a previous life I installed and repaired hundreds of Redring AD300 'traditional' hand driers, rebadged for that famous national rat-catching company.
I never measured the standby power, but given the failure rate of the 2W w/w resistors in the simple capacitor-diode-resistor power supply, I reckon the consumption was *at least* 2W... So heading for 20kWh per annum. With the 3kW driers then (I think they were 3.1 actually), about 6 hours' worth of drying time.
In an office washroom, standing time at the drier is assumed to be 25 seconds (gents) and 35 seconds (ladies).
Or about 600 drying visits.
A number of locations we had to install the things, I doubt they were used once a day.
I expect the effects of the increase heat & humidity on the air handling plant eclipse even the standby power consumption....
 05 September 2012 03:40 PM
fredman
Be totally green.. Shake the water off
On the serious side, why can't some of these large places use the wasted heat off the AC plant, always think it is great to stand on the top of a building in London in the winter at night and watch the amount of cooling tower vapour that is going up in the air.
 05 September 2012 07:24 PM
very often it is at too low a temperature to be of use - Q(kW) = mass x specific heat capacity x temperature difference. For the same fluid, the temperature difference dominates so you need as high a rejection temperature as possible to be able to reclaim. That's not efficient for the cooling system.
Many chillers will have free cooling cycles that make use of low ambient temperatures
That said, for many buildings, the cooling load dominates - you don't actually want the heat at any time of the year - so systems are constantly rejecting heat to some lesser or greater degree.
If we are serious about it, actually the building regs promote the problem - take an aspect as a minimum U value on a window - it's intended to stop winter heat loss - but it effectively stops summer heat loss as well - so you need more cooling power in summer - which equals more energy - much more than in winter as most buildings are almost self heating due to occupancy, PC and lighting loads etc. Relaxing the glazing U value would result in more heat energy being lost - but would also mean less cooling energy - balanced over a year a cheap single glazed window would actually be more energy efficient - can we do it, no - but thats building control for you
Going back to BOD's original post - in some cases using "efficient dryers" the quiescent load can be quite frightningly high - we had one building that used to trip a consumption alarm on landlords core power boards at night as the systenm was set to asume very low amps - but the hand driers used to achieve a trip point even if there was no usage
 05 September 2012 07:42 PM
I always thought that trousers make ideal hand dryers. They certainly work in those places where the paper towels have run out and the electric dryer is broken
 05 September 2012 07:49 PM
perspicacious
Both dryers tested out at 49 mA so just shy of 12 W each equating to 103 kWh annually or 20 male drying visits every day (as if).
BOD
 05 September 2012 09:33 PM
KFH
I worked for one company that replaced all the electric hand dryers in their new office with roller towels as they considered the aerosol effect of the hand dryers to be a health risk. That was before the Dyson type of dryer.
 05 September 2012 10:20 PM
Our local boiler factory owned by the highly efficient Germans have boilers on Z tests which means that they have had some them running flat out for over ten years, I passed comment that they are must never be short of hot water for the cloakrooms and was told that actually it is all sent to waste, calculate that one!
Andy
 05 September 2012 10:30 PM
peteTLM
Is that the dyson one that blasts all the water onto the floor then?
 05 September 2012 10:49 PM
The one that embarrasses us old men making it look like we dribbled on our shoes.
Andy
 05 September 2012 10:53 PM
It isn't considered polite is it to put your bits in the dryer is it?
 30 April 2013 03:47 PM
oshta
Originally posted by: sparkingchipOur local boiler factory owned by the highly efficient Germans have boilers on Z tests which means that they have had some them running flat out for over ten years, I passed comment that they are must never be short of hot water for the cloakrooms and was told that actually it is all sent to waste, calculate that one!
Ditto engines/gensets on dynos, where the energy all goes into..... load banks!! Cost of an inverter to stuff it back into the grid anyone?
Daniel
 30 April 2013 04:21 PM
rougediablo
Dyson Air Balling
 30 April 2013 07:29 PM
mikejumper
Yes, but whose trousers?
 01 May 2013 12:36 AM
SKElectrical
How would you counter the cold air brought in by fresh air requirements? With single glazed units it would take a colossal heating supply.
Or you thinking natural ventilation via infiltration?
You're on to something though - there is so much energy waste in office blocks.
 01 May 2013 09:44 AM
same as we always do - frost protection battery, pre heat battery and re heat battery depending on the amount of recirc or via two stage heating if 100% fresh with heat recovery on the AHU's (plates, run around coils, regenerative thermal wheel, heat pipes of heat pump)
The relative heat loss and gains of a single compared to double glazed unit isn't that great contrasted against the energy consumed in the shoulder parts of the year for cooling. There has to be something wrong with a building in a temperate maritime climate like the UK that has chillers runing in April because the heating is off and the building is overheating on nothing more than internal occupancy and equipment gains which can't easily "escape" because weve double glazed everything with low iron glass.
nope - natural ventilation is a properly designed ventilation arrangement - infiltration is just uncontrolled air movement due to crap building practices on site.
Build tight - ventilate right, remember
Exactly - that's why I made the comment
 01 May 2013 04:31 PM
amandalewin
I just want to know why men spend less time drying their hands?! Surely they have bigger hands, so would need MORE time?
Amanda
'At some point we all must chose between what is right and what is awesome'
IET » Wiring and the regulations » Today's teaser
