Topic Title: Galvanised Trunking Outside
Created On: 11 July 2018 02:13 PM
LACarbon
Hi all,
Opinions/regs on installing galv trunking to external walls (open to the elements as it were). Am i right in the minimum rating should be IP4X?
I am certain over a period of time the trunking will show signs of rusting being open to adverse weather conditions. Also screw holes/lid would allow ingress of water?
Carbon
 11 July 2018 02:19 PM
dustydazzler
I personally don't like galv trunk outside
 11 July 2018 02:28 PM
LACarbon
I personally don't like galv anywhere moisture or damp can arise, inside or out.
 11 July 2018 02:36 PM
Well, don't put anything in the trunking that matters if it gets wet, as it will. Maybe IP44. I do not think the regs say anything on this as it's not normally put out in the rain.
 11 July 2018 02:39 PM
dustydazzler
Vertical galv trunk would make a nice downpipe
 11 July 2018 02:43 PM
I agree that galvanised trunking outdoors should be avoided.
If for some special reason it is to be used, then IMHO it should be considered only as extra protection against mechanical damage, and that cables therein should be suitable for outdoor use.
 11 July 2018 02:54 PM
LACarbon
Thanks guys
Doesn't make a great down pipe either as water seeps out the sides
I couldn't find anything in the regs to say you couldn't either, I also didn't see anything that said I couldn't run my cables through puddles either but just because it isn't in the regs doesn't mean its okay to do
I personally think SWA should be the way to go
Carbon
 11 July 2018 02:56 PM
dustydazzler
Swa , or Sy
 11 July 2018 03:09 PM
dustydazzler
Originally posted by: LACarbon
Thanks guys
Carbon
Just seal the edges with window sealant
 11 July 2018 03:22 PM
LACarbon
Funnily enough, sealant was a recommendation for the trunking
 11 July 2018 03:23 PM
dustydazzler
Could always paint it with exterior metal paint ,
Nice shade of green would look nice
 11 July 2018 04:46 PM
deleted_1_vstrom1000
[text in this post removed]
Edited: 25 July 2018 at 09:57 AM by IET Moderator
 11 July 2018 05:15 PM
Zoomup
Certain metal trunking makers make a big thing of their product being IPX4 to keep out solid stuff like wires of 1.0mm dia or bigger up to 100mm long, but who would want to push a bare wire into trunking anyway? There is no discussion of keeping the rain out though.
http://www.youtube.com/watch?v=ePPliyKd_Ow
Z.
 12 July 2018 09:53 AM
The general requirement for trunking (containing unsheathed singles) is IP4X or IPXXD. IPXXD allows much bigger holes (up o 35mm across in some circumstances) provided the test probe is still clear of live parts. Neither rating of course provide any protection against water entry.
IP4X surely - IPX4 is protection from splashes (but no specified protection against solids)
 12 July 2018 10:59 AM
 12 July 2018 11:19 AM
tattyinengland
Definitely no to metal trunking run outside for me.
I would be willing to guarantee rust all over the show - even if only in the fixing holes, but probably at every cut (the installer - such as myself) - is unlikely to galv paint every cut joint perfectly and fixing hole.
If I had to run many circuits in this metal trunking, I'd be more likely to run a sub distribution supply to a new DB and then take my many circuits from there. Sub distribution circuit run outside in SWA perhaps.
 12 July 2018 02:12 PM
mikejumper
I agree.
As bad as using galvanised steel profiles on the corners of rendered external walls.
 12 July 2018 04:06 PM
chrispearson
Could we know a little more about the work please? Would conduit be too small?
 12 July 2018 04:40 PM
Zoomup
IP4X. Blinkin ek, my eyes are shot and now my fingers are working in reverse. I think it's time to hang up the neon tester and take up gardening.
Z.
 12 July 2018 05:18 PM
Well if you have deep pockets you can use IP66 trunking.
http://lasnek.com/products-uk/ip66-trunking
It probably wouldn't be on a general specification, but if you are looking for a link been buildings, perhaps to a plant room, then it's worth considering.
IET » Wiring and the regulations » Galvanised Trunking Outside
