Topic Title: Notify under Part P
Topic Summary: Hot Tub
Created On: 13 April 2018 10:33 PM
yellowvanman
If a hot tub is installed within a house should it be notified to Building Control under Part P regulations?
Part P document specifically only mentions rooms with a bath or shower!
 13 April 2018 11:03 PM
geoffsd
Is a tub not a bath?
 13 April 2018 11:08 PM
Otherwise it could be a swimming pool, though I would tend to settle for it being a bath, when installed indoors.
 14 April 2018 09:45 AM
dustydazzler
Isn't 'tub' an Americanism for 'bath'
I would say non part pee
 14 April 2018 10:01 AM
psychicwarrior
No (why would it need to be ?)
 14 April 2018 10:37 AM
dustydazzler
Only if it's part of a full rewire or consumer unit upgrade assuming the tub requires a brand new supply and doesn't just plug in
 14 April 2018 10:58 AM
It's only the electrical work that be would be notifiable, if it needs a new circuit or consumer unit upgrade.
I have two separate hot tubs to sort out next week.
The first has a moulded plug and trailing 10 mA RCD on it's attached flex, so only needs a outdoor socket off a existing circuit, so is not notifiable.
The second on is 28.5 amps and requires hardwiring with a new dedicated circuit, so is notifiable.
Andy B.
 14 April 2018 03:20 PM
Legh
Must be a Friday question !
Ask yourselves what makes a bathroom a bathroom in electrical terms...Do you not see a similarity with a bath and a tub? compare the amount of insulated clothing when climbing into a bath tub and a hot tub.
Will the control of heat and turbulence be within 600mm of the edge of the tub so what type of switches will be used?
Where would you expect to find the isolation?
Legh ........
de-avatared
 14 April 2018 05:44 PM
Silly me.
I thought the term was Location containg fixed bath or shower.
Therefore a special location therefore notifiable.
If it needs a new circuit would be notifiable anyway.
 14 April 2018 05:47 PM
PS Americans have daft names and daft pronunciation for stuff.
Data.
Tomato,
Iraq,
Colin.
and they get the date wrong as in 9 11 too.
 14 April 2018 06:14 PM
dustydazzler
I'm just off to rough in for some some new duplex receptacles using some 14 2 gauge Romex wire
 16 April 2018 01:02 AM
davyn1
Take it to a socket and just plug it in ??
just because i'm paranoid doesn't mean theyre not out to get me
