Topic Title: EngTech Topic Summary: Created On: 04 March 2010 01:03 PM Status: Post and Reply |
I would like to know if anyone has got EngTech status and what benefits did they find? I am considering applying but i am struggling to find any. Could i use it to negotiate a rise with my current employer? (i am a 'Trainee Electrical Engineer' at the minute. Thanks
I would say that yes it is worth applying for EngTech Status. But I try not too consider too much the 'cost-benefit analysis'.
Unfortunately, when you 'raise your game' you also raise your annual subscription fee... In a fair and just world, you would therefore expect your new status to improve your prospects and generally, I feel this is the case. Getting registered would certainly help add something to your CV. Doing your CPD also helps you get on in other ways. In my company many people seem to get irritated by some of the tasks we are assigned. This day and age their is a lot of change management taking place. For me, I have used some of this to my advantage by using it in my CPD and my development action plans. It also helps if you talk to your employer about your pursuit for registration, they may help you out by involving you with things you can use for your portfolio, or help out with some training costs or even with your membership fees. My experience is that employers like to see their staff being motivated. Being motivated and dilligent usually gets reflected in your salary review and seeking registration or doing your cpd is also worth a mention at appraisal time. At the end of the day, the choice is yours, although I do hope that you feel encouraged to go for your professional registration! Good luck and best wishes. |
I dont disagree with any thing BradC has said. However it depends what industry you work in. I have been EngTech for about 20 years and it has done me no good whatsoever. I do belive in registration and think it is one way to raise the image of the profession, I am currently considering changing to IEng but again I will not get any benefit from doing so. However if you are not part of the solution you are part of the problem.
I would make some enquirys around your workplace to find out if there would be any direct benefit, but would also encourage registration anyway. |
If you go through the process of measuring your competence, finding areas of weakness, setting action plans to meet the required levels and continuously reviewing, you will definitely get a lot out of it. This process will make you think about what you do and how you do it in a new way that will hopefully step your value as an employee up to another level.
Whether you will get any recognition from your employer because of this is another matter. Personally I have just finished building my case for IEng using the online career manager. It's been a worthwhile process and has definitely put me in a more "professional" state of mind about my career. Now I just need to decide if I should risk sending off a couple of hundred pounds (non-refundable) to see if I did the process right... |
Wilson479, I would suggest you run it past someone, for example a PRA. I would be more than willing to take a look if it would help you.
You have to remember, however that I am a Professional Registration Advisor and not a PROFESSIONAL Registration Advisor. ------------------------- David Parr BSc.CEng MIET PRA |
DavidParr
I have just completed a SVQ level 4 in construction site management which show on the IET as being recognised as level IEng which i am going to apply for. I feel little like wilson479 about the money being non refundable if i have misread what is required. May I ask how would i get a second opinion about this before sending off the application? Many Thanks |
Yes, send me a PM and we can take it from there!
