Topic Title: Ring Final Connection Blocks
Topic Summary: Ring Final Connections
Created On: 11 July 2013 12:17 PM
deleted_1_AngelLaHash
Basically I'm putting in a Ring Final and Lighting in to the Sheds.
Gots own DB off a 40A and then 32A for the Sockets and 6A for the Lights.
The RING is KILLING ME, pulling it in to all that trunking with so many bends in it (i was daft but got to keep going) Can i stop the ring at one point and use Terminal Block so i can stop, and points then keep going around till i meet the next socket.
Also the Earth, its ok to tap off the Ring Earth to the Lights or do they need there own line, really it will be only one or the other using the earth when it shorts, not every thing at once going down it.
(note im dyslexic so being funny passes me by, cant read emotions in to Text)
 11 July 2013 01:00 PM
ectophile
You'd be better off asking this in the Wiring and the regulations section of the IET forums.
S P Barker BSc PhD IEng MIET
 11 July 2013 04:48 PM
Thanks.. i guess forums aint for me.. i cant express things
Just wanted to know if i was ok to use terminal blocks in a Ring so i didnt have to do a long run
But ended up with 20 Questions in a Long Block of Text..
