Topic Title: Emergency lighting fittings - correct terminology Topic Summary: A difficulty in knowing what wiring is needed for an emergency lighting fitting. Created On: 28 April 2010 07:44 PM Status: Post and Reply |
I need to do a like for like replacement of a simple bulkhead emergency light fitting, The existing one is usually off but can be switched on, the wiring consists of unswitched live, switched live, neutral and earth.
When I go to the shop I am given the alternative of a maintained or a non maintained fitting. The maintained fitting is advertised as having the option of being switched but when I look inside, I find that the required wiring is live, neutral, earth and 2 wires to the switch, presumably because the switch circuit operates at a different voltage. Is there any way of knowing from the technical description whether the fitting requires a single switched live or a 2 wire circuit to the switch? |
Good question for the 'wiring and regulations' forum.....where I am sure you will receive a correct and quick answer.
Regards. |
Now posted in the wiring and regs forum - thanks
