Topic Title: Heating system switches?
Created On: 23 January 2012 12:28 PM
Avatar for marshall1975.
marshall1975
I'm preparing a paper on heating systems which work automatically, the basic idea being that a switch is required to turn the heating on when the temperature falls below a set value.
List temperature-dependent changes in materials properties (one each from gradual, accelerating and sudden) that could be exploited in a 'cold' sensor that could be used to turn the heating system on and off.
Taking it a step further could these be used in 0 degrees C?
Thanks...
 23 January 2012 01:07 PM
Avatar for dougflorence                                      .
dougflorence
Err... has the bimetallic strip thermostat not been invented already?
 09 February 2012 12:59 PM
oneye
You appear to describing the function of a frost 'stat.
Are you looking at something more sophisticated ?
Network Rail use a device which not only detects near 0 deg.C temperatures but also inclement weather - when it snows but air temperature is well above freezing.
 13 February 2012 08:14 AM
marshall1975
Thanks oneye sounds like what im after
