Topic Title: Low Voltage Lighting
Created On: 24 November 2010 08:34 PM
Southwest1984
Hi Guys,
As I may of mentioned before I am a rep for a national wholesaler and have a question regarding the energy consumption of 12v low voltage lighting. Am I right in saying that if you ran a 50w mains powered light compared to a 50w 12v light, the low voltage light would cost less to run due to the voltage?
 26 November 2010 06:48 AM
normcall
There I was thinking that 50w at 230v used a similar amount of energy as 50w at 12v.
Now, as Alan says, if you must transform the voltage, then use the still to be invented lossless transformer.
Norman
 20 December 2010 07:37 AM
dickllewellyn
You do however produce more lumens per watt with 12v halogen lighting, so with a bit of calculation, you may be able to prove it marginally more economical and ecological Particularly when you replace only one lamp a year as opposed to 4.
May be more prudent to fit GU10 now though, as retro-fit LEDs are coming on in leaps and bounds!
Richard (Dick)
 18 November 2011 04:12 AM
ethan7557
As Normcall have mentioned, the same 50watt lighting will consume the same power, no matter what voltages it runs, if for the 12v bulbs, you might also need a transformer, which also will consume more or less power. I think the most important point for you to promote the 12v lighting is the lumen efficiency, like if the 12v lighting is made of LED, efficiency of Link Removed can be over 100lm/w, over 10 times higher than efficiency of incandescent bulbs, 2 times higher than efficiency of CFL bulbs.
more detailed 12v led lighting advantage:
Edited: 18 November 2011 at 03:36 PM by ethan7557
