Topic Title: Car headlamps
Topic Summary: Does bigger mean less dazzle?
Created On: 07 December 2006 04:26 PM
amillar
A thought as I was driving home last night. There is a problem with car headlamps that they must be bright enough to illuminate the surroundings, but to achieve this we end up with two point sources that are not just uncomfortable to look at but can be positively dangerous (due to dazzle). If the light sources were distributed over the whole of the front of the car - possible with LEDs - would this be less dazzling for the same illumination? As a comparison, whilst I cannot look at a 100W tungstun bulb I can look at a 100W equivalent flourescent tube quite comfortably (because it is not a point source).
 07 December 2006 05:49 PM
sedgwicknc
Does this help at all?
http://en.wikipedia.org/wiki/Automotive_lighting
Best regards
sedgwicknc
 07 December 2006 06:04 PM
sedgwicknc
And this on pupillary reflex. Wikipedia did not seem to helpful on that, and I found this (but have only scanned and not read it). I think it covers both spectral aspects and subtended angle of the light source. Oh, and it's around 3MB, I think as scanned image (from the 1960s).
http://www.pubmedcentral.nih.g...=1359246&blobtype=pdf
Best regards
sedgwicknc
 08 December 2006 12:44 PM
amillar
Many thanks for the links; I think the latter may have some useful info in it, unfortunately slightly indigestible for a coffee-break thought, but if anyone feels like investigating further I would be fascinated to know what comes out (and hope they remember me when they've made their millions )
Edited: 08 December 2006 at 12:46 PM by amillar
 08 December 2006 02:56 PM
ahouston
Originally posted by: g3xoi
SNIP
I do not know whether such data is still available.
Probably not - or if it is, it's not used - judging by the number of cars with one or both dipped beams set at "dazzle me".
Andy
EurIng Andrew Houston CEng FIET
PRA, PRI and Volunteer Career Manager Advisor
Edited: 08 December 2006 at 02:57 PM by ahouston
 04 January 2007 03:43 PM
jcolquhoun
What usually gets you is the side lights and the front fogs on when visibility is about 2000 yards (which is a road traffic offence )
Or one car I noticed behind me one day had dipped headlights that flickered blue just like candle bulbs (mmmmmmmmmmm think they may be illegal)
Eur Ing John Colquhoun CEng MIET
Si Je Puis
Clarior Hinc Honos
Operations Manager - Telecommunications (Scotland) <img src="/forums/forum/i/expressions/face-icon-small-wink.gif" border="0">
 04 January 2007 03:53 PM
jcolquhoun
Just had another thought (I know they are rare )
My wifes car is a Volkswagon and the headlights have alloy caps on them. Wonder if they are used to reduce pinpoint glare from the focal point of the bulb?
Si Je Puis
Clarior Hinc Honos
 05 January 2007 09:28 AM
jcolquhoun
oh yea, forgot about that design.
The main thing about headlight glare is people forgetting to adjust the tilt when they have four friends in the car and the weight in the back causes the headlights to tilt upwards. Mibbey a course on what the little adjuster next to the dashboard is for
Having the luminescence spread along the width of the bonnet instead of the two points would probably increase the near field lighting but the main issue everyone has is the far field of vision which will still require a narrower beam and therefore increased intensity - back to square one when you look into the light
Si Je Puis
Clarior Hinc Honos
 24 February 2007 06:56 PM
CBMORLEY
There seems to be at least three factors to headlight glare.
One, dimwits who drive with foglights all the time.
Two, people who have obviously tilted their lights up so they can drive on dip all the time and don't have to use main beam.
Three, maladjusted lights due to damage or corrosion of the mounts, which should be picked up by the MOT but for the woefully poor testing of beam alignment.
 25 May 2007 10:40 AM
normcall
And the maximum wattage of the lamps rather than the little lumens are set out in the construction of vehicles requirements.
Norman
 12 July 2007 03:24 PM
Wasted
By law a motor vehicle is allowed only 55 Watts consumption headlamp and stoplamp bulbs.
But some motorcycle shops will supply vastly powerful bulbs if you just ask, though they are illegal to use on the road.
I run a 128/55 Watt on one of my motorcycles and I have a friend who runs over 150/55 Watts on his.
This is needed as many drivers just can't be arsed to dip when they see a bike coming towards them. A quick Close Encounters Of The Third Kind blast with the "Arc Lamp" soon makes them hit the switch.
I've managed to light up the cat's eyes around a car over half a mile away before now.
A lot of bikes run illegal high power headlamps as a safety measure.
And in answer to the original question, the illunination source doesn't matter as much as the lens system employed, which controls the distribution of the light energy, and the frequency of the light source, due to the way the human eye's various visual systems operate.
Projector headlamps were invented in the 1920's and were soon replaced by the superiour Prismatic Lens System which we still have today. They have returned,however, as a fashion gimmic on small scooters and car fog lights. However they are still obstelete.
There is a lot of serious engineering and development put into some headlamp designs though some other seem to have been styled by art graduates than engineers.
 14 September 2007 08:27 AM
amillar
Interesting article in this month's "New Electronics" here
 14 September 2007 05:34 PM
mbirdi
Talking of headlamps, several weeks ago I was driving back home late at night and saw a truck coming the other way, with the front covered full of headlamps. I mean there were about a dozen of them protruding along the top and bottom rows not to mention the headlamps that actually came with the truck. As I remember it only the front two headlamps were on at the time.
As the truck came closer, I naturally pulled over to one side to let it pass by.
You know when you let someone through and they flash their headlamps to say thanks. Well this one went one better and flashed the whole set to say a big thanks.
It was like starring into one of those floodlights at a football match. Except this one was about 5 meters away.
Awesome!
Edited: 14 September 2007 at 05:37 PM by mbirdi
 04 January 2008 04:43 PM
jimfraser
Somewhere in the depths of my storage space I have a copy of a British Standard for calibrating beam setters. It refers to placing the vehicle 8m (was 25') from a vertical wall and setting the root of the angled part of the beam directly ahead of the lamp and with the lower part of the beam at a height no higher than the centre of the lamp.
It is rare to find a garage that will set lamp properly. Normally, the only concern is to set the lamps low enough to pass the legal (1050mm?? Was 3'6".) dazzle limit when on dip and set the angled part far enough left: MoT pass. Whether the driver can actually see where he is going seems irrelevant.
I have just bought another car. I was out last night in the supermarket car park with my tape measure and my piece of chalk. Sorted!
(I still maintain that proper headlamps are round, 180mm in diameter and are marked 'Made in France'.)
 07 January 2008 05:01 PM
POTTERSBARNICK
Headlights are fitted to cars vans and HGV and motorbikes, when you take into account the range of sizes from micro minis to big 4x4 a headlamp tester has to test all, you can only check beam angle ie pointing downwards and dip down and n/s if it falls within the box it passes, and of course roads bend raise and fall so you could find some ones beam directly at you. And if your in a small car that four wheel jeep will have its headlights at your eye level. Trouble with headlight
adjusters most drivers dont have a clue what to do with them ,ie does winding it down put lights down or up?
 08 January 2008 09:43 AM
AlanKay
As a frequent traveller to France with my car, I am reminded how inefficient its headlights are rendered by the obligatory masking of the lens downswept-beam portion.
Its probably as I imagine driving those staff cars seen in wartime movies, where only a small slot was cut out of headlight full masks. I'm sure I've seen British cars (probably of German manufacture) where operating a simple mechanical lever at the rear of each lamp housing was all that was needed to convert the headlights to full brightness and correctly-dipping mode for continental driving. Or was that another of my wishful dreams? ;-)
Alan Kay, CEng MIEE
 13 December 2008 10:01 PM
Paul1966
The Road Vehicle Lighting Regulations 1989 specify that vehicles first used from 1986 onward are required to have lamps bearing appropriate approval marks. I'm not familiar with the contents of the applicable standards, so the 55W limitation might apply to headlights on newer vehicles.
But certainly as far as pre-1986 vehicles are concerned, the only requirement listed in the regulations is the headlights be a minimum of 30 watts. No maximum is specified (see schedules 4 & 5).
For stop lights, the permitted range of power rating is 15 to 36 watts for 1971 vehicles onward, and no specific requirement for older cars (see schedule 12).
http://www.opsi.gov.uk/si/si19...19891796_en_1.htm#tcon
Edited: 13 December 2008 at 10:03 PM by Paul1966
 08 May 2009 09:18 PM
ess1uk
sure i've heard of these too
 11 May 2009 08:15 AM
mmcgregor
In reply to the original post. I think the idea that a distributed light source would be less dazzling for the same illumination is a good one. That seems to be the experience in football grounds where lighting gantries across the whole length of the stands has, in recent years, replaced the old floodlight pylons.
 23 November 2009 03:34 PM
amezcua
On my first visit to this site I made the mistake of putting headlamp glare into Emerging Technology.
If I knew how to move the topic here life would be simple. If you look you will see a good cheap way to avoid headlamp dazzle.Maybe I should run through it all again here.
IET » Transport engineering » Car headlamps
