Topic Title: induction single fase motor
Topic Summary: help needed with a wiring problem
Created On: 25 February 2014 09:34 PM
irishron40
hello. i have a large induction motor .
more info and picture i posted here Link Removed ww.esatclear.ie/~ronvos/inductionmotor/index.html
I do not know much about these.
I have connected it but dont have a capasitor yet.
when i switch it on i hear a humm and when i turn pulley it starts
after about 2 seconds it seems to switch of and on and of and on.it doest reaches top speed,
why would this be? is it because i dont have a capasitor connected?
aslo on the inside is a little black switch with 2 heatproof wires. is this a overload switch? and does this need to be wired up and how? thx very much.
ron
Edited: 26 February 2014 at 01:39 AM by irishron40
 27 February 2014 08:11 AM
oneye
From what you have described it would appear to me:
- the device which has two heat resistant wires could be a thermal cut-out
- it's not clear why you have tied two wires together
- the capacitor is for initial starting which you have overcome by manual rotation
- the connection which you have to supply would appear to be for starting only if you state it cuts out when running (a mechanical speed switch?)
I would suggest when you do have a capacitor, it is placed in circuit which I have described for starting only.
The other wires may be for the motor main winding; It's not clear what tools you have to check this.
I trust you know the direction of rotation.
If you do get it to work, you would place the thermal cut-out in circuit to disconnect the supply on overtemperature.
Of course all the above is guesswork, and it is up to you to work safely.
I would start at low voltage and work upwards.
Finally the motor manafacturer could be Crompton Parkinson.
 28 February 2014 09:31 AM
jonsmith62
Hi,
From your pics
It looks like a 1/3hp single phase resilent mount washer motor
If it is then there are two windings, start and run, a centrifugal switch and a thermal overload. These motors don't require a capacitor to start as the start winding is physically shifted on the stator.
If I remember correctly these motors where fitted to servis single and twin tub washers in the 60s.
Hope this is of use.
Jon
