Topic Title: Advantages of Steam Boiler to Look At
Created On: 28 January 2014 06:33 AM
Where is my avatar image?
scottmatthew
A steam boiler has gained more popularity over combustion engines for generation of steam. Combustion of fuel has got all the major disadvantages which can be overcome by using a steam generator.
Some of the advantages of using steam boilers are:
. Less environmental hazards like air and noise pollution.
. Does not require separate chambers
. Easy installment
. Automated functioning for detecting leaks and holes.
. Just need the supply of water and no requirement of fuels.
. Discards the requirement of separate chamber for fuel storage.
. Easy maintenance
. Require electricity to operate.
. Cheaper than combustible engines.
You will come across a steam boiler in different capacities like low, medium and high capacity requirements. They have all the pre installed functioning like detecting the level of water and pressure. Requires less labor to deal with, thereby decreasing all your expenses.
Advantages of a Used Steam Boiler over New Boilers
A used steam boilerused steam boiler has got a lot of disadvantages. If you opt to buy an old boiler then there are a lot of disadvantages in it. Previously steam boilers were not automated and require manual concentration. They were considered as one of the dangerous machines. They got a lot of fitting and safety issues. They even require time to time testing. You have to regularly check the water level and take pressure readings. There was no such mechanism to detect water leaks. If you still use an old steam boiler, then it's better to replace the old one with the latest and automated boiler.
