Topic Title: TUV or TXU fuse??
Created On: 12 March 2013 12:28 PM
irnbru
With regard to a new DB I have been asked if it is fitted with TUV or TXU fuses
What is/are the difference between the two?
 12 March 2013 05:40 PM
dlane
No I am not too sure either.
A TXU fuse could be referring to the class of fuse, its rating and bolt pattern etc, but I haven't come across a TUV class fuse.
On the other hand TUV could be referring to the German standards organisation, but I haven't come across a TXU standard.
We will both be waiting for a more learned response....
Kind regards
Donald Lane
 12 March 2013 07:55 PM
oneye
TXU appears to be prefix to Alstom Redspot fuses - It's not clear whether TUV relates to as stated the German standard or another.
An Austrailian Shortform:
http://www.ipdgroup.com.au/WMS...0sec%201%20BS%20NH.pdf
 13 March 2013 10:16 AM
irnbru
I think you are on the right lines with the bolt pattern Donald.
TXU = 00
TUV= 0
0
0= Mounting bolt hole on either end of fuse
I think!!
 13 March 2013 01:01 PM
dlane
It can happen on the odd occasion!!
I have come across fuses stamped up TXU that have a double bolt fixing at each end rated 1000A and above.
I haven't seen a fuse stamped as TUV, although have seen some references now from a google search so it may be a designation for a foreign country to me.
Can you not just supply the specification of the incoming fuse to the client to answer their question?
Kind regards
Donald Lane
IET » Energy » TUV or TXU fuse??
