Topic Title: 11kV Overhead Line Typical Values
Topic Summary: Power
Created On: 01 December 2010 05:01 PM
dl305
Hello
I'm a part time student currently studying an Electrical Engineering degree and my final year project is based on modelling a proposed on-shore power generation system using an electrical engineering software tool to analyse load flow, short circuit, voltage rise, protection etc. However, as my background is oil&gas and process plant, I'm lacking all the data to input into the model for 11kV overhead lines. Would anyone happen to have a table (or know where I could find one) providing typical values for resistance, capacitance, reactance susceptance B with zero,1,2 Sequence values etc?
Any help would be much appreciated.
What can happen, will happen.
 06 December 2010 09:16 AM
boneillfnc
Hopefully this will point you in the right direction. Two references
Try cable manufactuers datasheets for the electrical properties, you will need to know the length of the cable
http://www.aeicables.co.uk/
and
Electric Cables Handbook avalaible via the IET knovel ebooks, specifically chapter 10. This will give you a hand with Positive, Negative and Zero Sequence Impedance for cables.
Ta
Bryan
 07 December 2010 04:19 PM
dl305
Thanks very much for this Bryan, much appreciated.
