Topic Title: wrong energy meter reading Topic Summary: Created On: 29 March 2010 05:19 AM Status: Post and Reply |
we have installed 3ph energy meters for four 33kV feeders connected to the Grid substation to measure import/export energy. But at the end of the month all energy meters indicate 2/3 of actual reading. (Actual reading got from the old meters). Is there a common reson for this type of errors.
Check the voltage inputs and current inputs to meters. It is easy to speculate that you have missed out input from one phase.
Regards Chris Chew |
What type/make are your energy meters? Perhaps they have a set up menu? Are they configured/wired OK. Could you contact supplier applications engineer for advice?
Relay type is EDMI geinus MK5. it has two options for connection. one is 3ph four wire system and other option is 3ph three wire system.Is it a VT arrangement or actual phase arrangement.
our 33kV feeders start from 33kV delta side of the 132/33kV T/F . |
» Energy
