Topic Title: Voltage Contour plot - IEEE80-2000 - Simple equations?
Topic Summary: IEEE80-2000 Voltage at a point X metres away from the earth gird / within a mesh - Equations
Created On: 29 September 2009 05:02 PM
Avatar for icoggan.
icoggan
I want to know the equations for calculating the approximate voltage at a point X metres away from an earthing grid I have designed.
I have seen many pictures of these kind of plots, I know some come from FEA techniques - I do not intend to get into that. See page 10 of IEEE80-2000 for an example.
I have a complete model of my earthing grid & rods in Mathcad and can calculate all the critical design values such as Step / Touch Voltage, based on IEEE80-2000, once the input data is defined.
I want to create a contour plot of the voltages within the grid meshes and also the tail off in the area surrounding the installation - its not exactly critical - this is a design verification tool - but it would be good to find out how to achieve this.
Ian Coggan
 19 July 2012 02:38 PM
nilushka
Im interested in solving exactly the same problem. did you find a method to derive voltage contour plots inside a mesh?
 25 July 2012 03:26 PM
Avatar for icoggan.
icoggan
Sadly I never found an equation which would help me solve this problem, I came to the conclusion that ETAP etc must utilise Finite Element Analysis to produce the contour plots.
Perhaps there is some help within BS 7430:2011 (perhaps section 9.6.2.2)? If you do ever find an answer I would appreciate you posting it back into this forum!
Regards, Ian
