Topic Title: electrical loads
Topic Summary: total amps
Created On: 09 October 2012 07:59 PM
justin40
i have a small building to wire. i have added up the electrical load of the circuits allowing for diversity on the sockets and have a load of 244 amps. that load is this in real terms. the exising building is huge and is only taking 100 amps i am told. the have allowed 40 amps over 3phase to cover the additional building. im guessing some think needs to be done to the 244 amps.
helpplease
 16 October 2012 11:55 AM
Avatar for MAXMIRA.
MAXMIRA
Hi Justin,
How many sockets do you have and have you used a realistic diversity factor. Also, when assuming the loads of the sockets do you have any information on what is going to be plugged into them?
Is the 244A to be spread over the three phases?
Is there only sockets to be supplied?
David
 21 October 2012 11:41 AM
ectophile
You say it's a small building, but 244A at 230V is 56kW.
Are the total loads in the building really going to add up to 56kW? If you start dissipating that much heat in a small building, will everything inside be cooked?
S P Barker BSc PhD MIET
 29 November 2012 02:27 PM
Westonelectrical
56kw forget the cooking of the building.. What about the cost!!
 14 January 2013 08:04 AM
fullcircleltd
Fullcircle is a leading provider within the facilities management and building industries, with a service offering including: building, grounds maintenance, landscaping, Electrical work, security, specialist cleaning and water & ventilation hygiene.
 14 January 2013 09:00 AM
ENYABASSEY
Justin , please to be on the safe side , calculate your Diversity Factor; that will give you the right cable , socket switches etc
