Topic Title: Question About Conduit Threading
Created On: 18 April 2012 12:40 AM
jeepspark
Hi - again, I hope this is the correct forum for this query - am going to be threading 20mm galvanized steel conduit. I have been supplied with a bender and a set of imperial dies, such as 1/2", 3/4" etc. I believe these are BSP thread sizes. My question is, should I be using a 20mm die, or is that the same as 1/2" BSP? Thanks, John.
 18 April 2012 12:16 PM
ArthurHall
The dies wont be BSP. BSP threads are deeper and have a bigger pitch.
3/4 conduit and 20mm conduit are similar but not quite the same. the threads are different, if fact you can get conversion nipples that convert a 3/4 male thread to 20mm male. unless you have a supply of 3/4 fittings invest in a 20mm die, it should fit in your existing stocks.
 18 April 2012 12:35 PM
jeepspark
Thanks very much, that seems to clear things up
