Topic Title: OLE Data Extraction from Specific Drawing Object at Amazon S3 Storage
Created On: 16 January 2013 06:42 AM
saaspose
This technical tip allows developers to Link Removed using Saaspose.Words REST API in your .NET applications. You need to upload file to Amazon S3 storage before running this example. Some important steps for performing this task are to specify product URI, Choose from jpeg, tiff, png and bmp, build URI, sign URI, get response stream, required methods and classes are also given in detail. Please check Saaspose example section for more details on how to upload files to Amazon S3 storage.
Sample Code for Extracting Ole Data from a Drawing Object at Amazon S3 Storage
SaasposeApp.AppKey = "9a******************";
SaasposeApp.AppSID = "77*********************";
//specify product URI
Product.BaseProductUri = @"Link Removed
try
int drawingObjectIndex = 1;
string fileName = "SampleDrawingObject.doc";
string saveFormat = "xls"; //Choose from jpeg, tiff, png and bmp
string outputFile = "C:\\OutputDrawingObject." + saveFormat;
string amazonS3StorageName = "MyAmazonS3Storage";
string amazonS3BucketName = "MyS3Bucket"; // include folder name if file is not at root folder
//build URI
string strURI = Product.BaseProductUri + "/words/" + fileName + "/drawingObjects/" + drawingObjectIndex;
strURI += "/oleData?storage=" + amazonS3StorageName + "&folder=" + amazonS3BucketName;
//sign URI
string signedURI = Sign(strURI);
//get response stream
Stream responseStream = ProcessCommand(signedURI, "GET");
using (Stream fileStream = System.IO.File.OpenWrite(outputFile))
CopyStream(responseStream, fileStream);
responseStream.Close();
catch (Exception ex)
Console.WriteLine(ex.Message);
//Following are the required methods and classes
public static string Sign(string url)
try
// Add appSID parameter.
UriBuilder builder = new UriBuilder(url);
if (builder.Query != null && builder.Query.Length > 1)
builder.Query = builder.Query.Substring(1) + "&appSID=" + SaasposeApp.AppSID;
else
builder.Query = "appSID=" + SaasposeApp.AppSID;
// Remove final slash here as it can be added automatically.
builder.Path = builder.Path.TrimEnd('/');
// Compute the hash.
byte[] privateKey = System.Text.Encoding.UTF8.GetBytes(SaasposeApp.AppKey);
System.Security.Cryptography.HMACSHA1 algorithm = new System.Security.Cryptography.HMACSHA1(privateKey);
//System.Text.ASCIIEncoding
byte[] sequence = System.Text.ASCIIEncoding.ASCII.GetBytes(builder.Uri.AbsoluteUri);
byte[] hash = algorithm.ComputeHash(sequence);
string signature = Convert.ToBase64String(hash);
// Remove invalid symbols.
signature = signature.TrimEnd('=');
signature = System.Web.HttpUtility.UrlEncode(signature);
// Convert codes to upper case as they can be updated automatically.
signature = System.Text.RegularExpressions.Regex.Replace(signature, "%[0-9a-f]{2}", e => e.Value.ToUpper());
// Add the signature to query string.
return string.Format("{0}&signature={1}", builder.Uri.AbsoluteUri, signature);
throw new Exception(ex.Message);
public static Stream ProcessCommand(string strURI, string strHttpCommand)
try
Uri address = new Uri(strURI);
System.Net.HttpWebRequest request = (System.Net.HttpWebRequest)System.Net.HttpWebRequest.Create(address);
request.Method = strHttpCommand;
request.ContentType = "application/json";
request.ContentLength = 0;
System.Net.HttpWebResponse response = (System.Net.HttpWebResponse)request.GetResponse();
return response.GetResponseStream();
catch (System.Net.WebException webex)
throw new Exception(webex.Message);
catch (Exception Ex)
throw new Exception(Ex.Message);
public static void CopyStream(Stream input, Stream output)
try
byte[] buffer = new byte[8 * 1024];
int len;
while ((len = input.Read(buffer, 0, buffer.Length)) > 0)
output.Write(buffer, 0, len);
public class Product
public static string BaseProductUri { get; set; }
public class SaasposeApp
public static string AppSID { get; set; }
public static string AppKey { get; set; }
