Topic Title: Need to step up voltage from 1.2V to 5V in seebeck pelteir plate setup
Topic Summary: Need to step up voltage from 1.2V to 5V in seebeck pelteir plate setup
Created On: 17 January 2014 10:51 AM
yigiter007
My project is that I want to USB fire charger. Its a device that you place on or near fire that will use the Seebeck effect of a pelteir plate to charge a USB device.
So far I learned that i will only get 1.2 volts from a pelteir connected with a Schottky diode. USB ports need 5 V to charge any device.
I looked online on ways to step up voltage and the thing i found is a charge pump. Is the only way to step up voltages from 1.2 V to 5 V. I also found this link that steps up a solar panel voltage to 5 V, could the panel be swapped with a pelteir plate. (Link Removed
Thank you for your replies in advance.
 17 January 2014 01:01 PM
ANFierman
You can try googling for:
"peltier seebeck effect step up converter charger"
I found these:
http://www.scraptopower.co.uk/...ic/thermoelectric-pan
http://hackaday.com/2013/12/02...vesting-peltier-ring/
http://www.instructables.com/i...rger-Powered-by-Fire/
You will need to read up about step up converters. Switched capacitor is a very crude and not very efficient way to do it.
Have a look here:
http://en.wikipedia.org/wiki/Boost_converter
http://www.onsemi.com/pub_link/Collateral/SMPSRM-D.PDF
http://www.smps.us/Unitrode.html
Most of the major semiconductor manufacturers supply boost converter chips, many with evaluation boards.
Andy Fierman
http://signality.co.uk
 17 January 2014 06:00 PM
kengreen
How about the nasty techniques used in switcher PS?
Chop the dc-input, step-up transformer, fw rectifier - quite safe at 1 to 5 volts.
Ken Green
