Topic Title: Matrix Processing Core VHDL Topic Summary: Created On: 24 December 2012 04:24 PM Status: Post and Reply |
I am doing a project called Matrix Processing Core and I had written the codes in Xilinx for it. However, the ISE could not Map,Place and Route my codes. There was no written error so I hope some one can help pin point my mistake. Below are my codes:
library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.NUMERIC_STD.ALL; -- Uncomment the following library declaration if using -- arithmetic functions with Signed or Unsigned values --use IEEE.NUMERIC_STD.ALL; -- Uncomment the following library declaration if instantiating -- any Xilinx primitives in this code. --library UNISIM; --use UNISIM.VComponents.all; entity MatProCore2 is Port ( Reset, Clock, WriteEnable, BufferSel, OP : in STD_LOGIC; WriteAddress : in STD_LOGIC_VECTOR (3 downto 0); WriteData : in STD_LOGIC_VECTOR (7 downto 0); ReadAddress : in STD_LOGIC_VECTOR (3 downto 0); ReadEnable : in STD_LOGIC; ReadData : out STD_LOGIC_VECTOR (8 downto 0); ReadReady : out STD_LOGIC); end MatProCore2; architecture Behavioral of MatProCore2 is COMPONENT dpramA -- DPRAM A PORT ( clka : IN STD_LOGIC; --Clock wea : IN STD_LOGIC_VECTOR(0 DOWNTO 0); --WriteEnableA addra : IN STD_LOGIC_VECTOR(3 DOWNTO 0); --Address Port A DPRAM A dina : IN STD_LOGIC_VECTOR(7 DOWNTO 0); --Input DRRAM A clkb : IN STD_LOGIC; enb : IN STD_LOGIC; --ReadEnable A addrb : IN STD_LOGIC_VECTOR(3 DOWNTO 0);--Address Port B DPRAM A doutb: OUT STD_LOGIC_VECTOR(7 DOWNTO 0) -- Output DPRAM A ); END COMPONENT; COMPONENT dpramB16x8 --DPRAM B PORT ( clka : IN STD_LOGIC; --Clock wea : IN STD_LOGIC_VECTOR(0 DOWNTO 0); --WriteEnableB addra : IN STD_LOGIC_VECTOR(3 DOWNTO 0); --Address Port A DPRAM B dina : IN STD_LOGIC_VECTOR(7 DOWNTO 0); --Input DPRAM B clkb : IN STD_LOGIC; enb : IN STD_LOGIC; --ReadEnable B addrb : IN STD_LOGIC_VECTOR(3 DOWNTO 0);--Address Port B DPRAM B doutb : OUT STD_LOGIC_VECTOR(7 DOWNTO 0) --Output DPRAM B ); END COMPONENT; COMPONENT dpram16x9 PORT ( clka : IN STD_LOGIC; --Clock wea : IN STD_LOGIC_VECTOR(0 DOWNTO 0); --WriteEnableC addra : IN STD_LOGIC_VECTOR(3 DOWNTO 0);--Address Port A DPRAM C dina : IN STD_LOGIC_VECTOR(8 DOWNTO 0); --Input DPRAM C clkb : IN STD_LOGIC; enb : IN STD_LOGIC; --ReadEnableC addrb : IN STD_LOGIC_VECTOR(3 DOWNTO 0);--Address Port B DPRAM C doutb : OUT STD_LOGIC_VECTOR(8 DOWNTO 0)--Output DPRAM C ); END COMPONENT; -------------------------STATESIGNALS------------------------------------- type statetype is (Idle, WriteIN, ReadIN, WriteOUT, Complete); signal PRESstate: statetype; signal NEXTstate: statetype; -------------------------------------------------------------------------- signal icounter: unsigned(3 DOWNTO 0); signal iWriteInputEnableA, iWriteInputEnableB, iWriteOutputEnable: STD_LOGIC_VECTOR(0 DOWNTO 0); signal iReadFromA, iReadFromB: STD_LOGIC_VECTOR(7 DOWNTO 0); signal iResizeFromA, iResizeFromB, temp: SIGNED(8 DOWNTO 0); signal iReadInputEnable, CounterReset, CounterON: STD_LOGIC; begin iResizeFromA <= resize(signed(iReadFromA),9); iResizeFromB <= resize(signed(iReadFromB),9); DPA : dpramA PORT MAP ( clka => Clock, wea => iWriteInputEnableA, addra => WriteAddress, dina => WriteData, clkb => Clock, enb => iReadInputEnable, addrb => std_logic_vector(icounter), doutb => iReadFromA ); DPB : dpramB16x8 PORT MAP ( clka => Clock, wea => iWriteInputEnableB, addra => WriteAddress, dina => WriteData, clkb => Clock, enb => iReadInputEnable, addrb => std_logic_vector(icounter), doutb => iReadFromB ); DPC : dpram16x9 PORT MAP ( clka => Clock, wea => iWriteOutputEnable, addra => std_logic_vector(icounter), dina => std_logic_vector(temp), clkb => Clock, enb => ReadEnable , addrb => ReadAddress, doutb => ReadData ); Global: process (Clock) is begin if RISING_EDGE(Clock) then if Reset = '1'then PRESstate <= Idle; else PRESstate <= NEXTstate; end if; if CounterReset = '1' then iCounter <= (others => '0'); else iCounter <= iCounter + 1; end if; end if; end process Global; Operations: process (PRESstate, WriteEnable, BufferSel, OP, iCounter, iResizeFromA, iResizeFromB) is begin ---Default values------------- NEXTstate <= PRESstate; CounterReset <= '0'; CounterON <= '1'; iReadInputEnable <= '0'; iWriteOutputEnable(0) <= '0'; ReadReady <= '0'; iWriteInputEnableA(0) <= '0'; iWriteInputEnableB(0) <= '0'; ------------------------------ if (OP = '1') then temp <= (iResizeFromA + iResizeFromB); else temp <= (iResizeFromA - iResizeFromB); end if; if (BufferSel = '1') then iWriteInputEnableA(0) <= '1'; else iWriteInputEnableB(0) <= '1'; end if; case PRESstate is when Idle => if (WriteEnable = '1') then NEXTstate <= WriteIn; else CounterReset <= '1'; end if; when WriteIn => if (icounter = "1111") then CounterReset <= '1'; NEXTstate <= ReadIn; end if; when ReadIN => iReadInputEnable <= '1'; CounterON <= '0'; NEXTstate <= WriteOut; when WriteOUT => iWriteOutputEnable(0) <= '1'; if (icounter = "1111") then CounterReset <= '1'; NEXTstate <= Complete; else NEXTstate <= ReadIN; end if; when Complete => ReadReady <= '1'; NEXTstate <= Idle; end case; end process Operations; end Behavioral; |
» Electronic engineering
