Topic Title: Control system design for flexible structures
Created On: 25 January 2013 06:49 PM
mahwishjawa
hey everyone,
i have to write a survey paper on Control System Design for Flexible Structures and this topic is completely new to me.. i have tried searching but it has been unfruitful so far.. can someone please tell me what actually these flexible structures are and how to start with this topic..
Edited: 25 January 2013 at 07:27 PM by mahwishjawa
 25 January 2013 08:25 PM
oneye
Despite many years experience I had to 'Google' this for an idea of what might be involved.....here's 2 ideas off the 'net:
1. http://automation.isa.org/2013...ng-input-constraints/
"Abstract: In this paper output unreachability under input saturation phenomenon is studied: under a large disturbance or setpoint change, the process output may never reach the set point even when the manipulated variable has driven to saturation. The process output can be brought back to the set point only by activating an auxiliary manipulated variable"
2. http://ieeexplore.ieee.org/xpl...%3Farnumber%3D5410416
"A Genetic Algorithm (GA) based approach for design of H¿ passive control for a flexible structure is presented. The flexible structure has six degrees of freedom and the control system is designed by using the H¿-control theory. The passive control is to minimize the H¿-norm from closed loop transfer function of the system which implies suppressing the magnitude peaks vibration of the frequency response. Parameters optimization of flexible structure system becomes an H¿-output feedback problem. This problem is transformed to Bilinear Matrix Inequality problem and then it is solved by using GA."
All I can say is - Good Luck !
