Topic Title: Control Panel & PLC comply with Marine Standard
Topic Summary: Which Standard we should use
Created On: 21 December 2009 05:44 AM
chang
Dear All,
Anyone know about which standard (For Example: Lloyd's Register) we should use for the control panel, SCADA, PLC and other control device and installation, which in the marine application?
Thank and Reagrds,
Chang
 21 December 2009 09:52 AM
emmaabbie
It depends on the class the panel is being used on, and what you are using the PLC for.
If you look at Lloyds for example you may need to submit a print out of the program for approval.
A far as I am aware as long you are using a factory standard software there should not be a problem
Adrian Ward, MIET, MBCS
 21 December 2009 01:57 PM
breynolds
Look at ISO 17894
Ships and marine technology -
Computer applications - General principles for the development and use of programmable electronic systems in marine applications
Barrie
Barrie Reynolds CEng MIET
Functional Safety TAP member
Chairman BSI GEL65/1 responsible for IEC 61508 and IEC 61511 in UK
