Topic Title: How Do I Improve DTV Signal Strength?
Created On: 05 November 2012 10:45 AM
cloudserver
Your DTV reception can be affected by terrain, trees, buildings, the weather, damaged equipment, as well as antenna type, location, and orientation. It can be improved just by changing the location of the antenna you're using now. Moving your antenna away from other objects and structures, or placing it higher, can often improve reception. The performance of outdoor antennas can degrade over time due to exposure to the weather. Also, you may consider installing a signal booster, which should improve reception. If you are having trouble receiving a broadcast:
Check your connections.
Perform a channel scan.
Adjust your antenna.
etc.
