Topic Title: Double Insulated Cable
Created On: 12 January 2015 01:39 PM
DaveCatt
Hi, I would like to hear your comments on jointing single core double insulated cables. Using a butt crimp connector, how would one insulate the joint to maintain the integrity of the double insulation?
 12 January 2015 02:03 PM
As all joints should be in an enclosure (reg 526.5), I'd simply use an insulating box to an appropriate standard.
 12 January 2015 02:24 PM
Zimmerman
You could look at the wiring used in Photo PV installations. The use double insulated connections on the down wiring (DC side) and connections/connectors as I recall
 12 January 2015 03:09 PM
Although the single core cable has 2 layers of insulation that doesn't apparently make it "double insulated", We've had long discussions on this matter before! It's like twin & earth, again 2 layers but it's technically insulated and sheathed, not double insulated. In your case i'd say put the joint in an enclosure of some sort, or maybe use heat-shrink sleeving?
 12 January 2015 04:47 PM
bajb
MC4 plugs/sockets are used to join solar cables and can be in fresh air if you do not want to use crimps in an enclosure
 12 January 2015 05:39 PM
Although it can be 'considered to meet' the requirements of double insulation (see reg 412.2.4.1).
 12 January 2015 05:51 PM
I know Andy, it seems so daft doesn't it. Because double means two in the English language I still consider that 2 layers of insulation mean "double insulated"!
 12 January 2015 06:25 PM
Phillron
Do you mean there is no difference between "double standards" and 2 standards" for example
Only joking by the way lol
