Topic Title: MEM Glasgow switch fuse & multiple lugs
Created On: 10 August 2014 09:10 PM
Smith249
Guys, got an installation that has 100A SPN MEM Glasgow switch fuse as the main switch. It comes out of the meter, into the switch fuse and then onto the DB.
I want to add another DB next to the current one. The lug studs on the MEM main switch outgoing terminals are about 25mm long and plenty of wire room adding another set of lugs would still leave loads of thread left for the nut.
Is this considered rough having more than one lug on the stud? I don't want to fit Henley blocks as its all currently in steel trunking and would look much neater without them, also bus-bar chamber would be OTT
Thanks.
 10 August 2014 09:21 PM
Well I reckon it's fine. But others might not so we had better wait for the debate before deciding. To me, two lugs together under a big bolt is not an issue.
 10 August 2014 09:58 PM
prophet
Well whether rightly or wrongly i have done it.
If possible i'd have the lugs the other way round to each other (so the flat sides are together).
Tom
 10 August 2014 10:03 PM
I'm with Tom, seen it and done it from time to time. You do need the flat sides together otherwise the lugs tend to rotate but there should be enough room in a MEM switchfuse to achieve it
 11 August 2014 12:17 AM
industryspark
Seen it done lots of times and have done it myself.....i actually know of a switchfuse with 4 lugs on the stud which has been operating fine for 12+ years.....
Nothing wrong with double lugs although i admit, 4 is pushing it!
 11 August 2014 02:03 PM
burn
Its fine. How else would you use parallel sub main cables?
burn
