Topic Title: Really Daft Question.... Yes really
Created On: 25 February 2014 10:31 AM
antdon
Ok
why cant I connect a single phase load to a 3ph mcb??
Are the characteristics really that different?
 25 February 2014 10:48 AM
MrP
A triple pole 60898 MCB comprises of 3 single pole 60898 MCBS strapped together therefore yes you can use a single pole of three and why not
Good luck buddy
MrP day 7
 25 February 2014 10:58 AM
Yes you can. (presuming that a neutral is available in the DB)
As above, most 3 phase MCBs are in fact 3 single phase units attached together.
Also consider that some 3 phase loads may under some circumstances only load 1 phase, and no one worries about that.
As an example I have a 3 phase portable fan heater of 18KW output and fitted with a 32 amp 3 phase and neutral plug.
This appliance has 3 heat settings, and if used on the lowest setting is in effect a single phase 6KW heater.
Used thus it would still be properly protected by a 32 amp 3 phase MCB in the DB.
 25 February 2014 11:06 AM
rogersmith7671
Ok
You can.
The characteristics of each mcb have been designed to meet the requirements of the circuit designer, so there will be differences
But a type b mcb is a type b mcb, it's just three clipped togther.
 25 February 2014 12:19 PM
AdrianWint
Yes can connect a single phase load to a three phase MCB.
However, you shouldn't connect three separate single phase loads to a three phase MCB.....
A three phase overload module would however be a different matter.......
 25 February 2014 01:31 PM
MrP
Where does it say you can't ?
MrPstill day 7
 25 February 2014 04:25 PM
antdon
Many thanks for all the replies.....
 25 February 2014 04:49 PM
Jaymack
The regulations call for a means of isolation. They also call for minimum disruption, this wouldn't comply.
 25 February 2014 04:56 PM
A bit like feeding half a house worth of MCBs from the same RCCB you mean?
