Topic Title: Rewiring lighting in old conduit
Created On: 24 February 2014 07:19 PM
ryespark
Hi guys
Am attempting to rewire the lighting circuit of a 1930s flat run in metal conduit tomorrow for the first time.
Any tips for pulling the new singles in? Do you simply pull it though using the old wiring?
Many thanks
Ryan
Ryan Andrews
http://www.electrician-hampton.co.uk/
 24 February 2014 07:48 PM
Fm
Which floor is the flat?
Top floor hopefully! Cut the conduits in the loft and rubber slip on grommet and wire in t and e?
Get some lube, plenty tape and a mate for pulling as you feed in if its in singles
 24 February 2014 07:50 PM
ryespark
No ground floor I am afraid, always talked myself out of quoting for jobs like this before as have never done it, but it's time to give it ago.
Ryan Andrews
 24 February 2014 07:53 PM
aligarjon
Watch the earth continuity on it if its that old. Good luck.
Gary
 24 February 2014 07:55 PM
ryespark
Hi Gary,
Was going to try and pull a cpc in if it fits
Ryan Andrews
 24 February 2014 07:56 PM
peteTLM
run a cpc with the circuits as the old slip conduit (or any conduit that old) isnt going to be up to much.
 24 February 2014 08:08 PM
aligarjon
I was meaning that it will still need to be earthed so may need to be connected at several accessories. I did one of these a few years back , it was a challenge
Gary
 24 February 2014 10:22 PM
Fm
A tenby clamp on the conduit at the db if it doesnt end in a box.
 24 February 2014 11:10 PM
largelunchbox
Originally posted by: ryespark
Hi guys
Many thanks
Ryan
hi
i find these type of rewires can be the easiest,especially if no new locations are required, hopefully the conduit will not have collapsed any place and you should have it done in 2 days.
 24 February 2014 11:11 PM
largelunchbox
correction,half a day if it only the lighting
 25 February 2014 06:39 AM
normcall
In my experience, 1930's purpose built flats are in screwed tube - if you are really unlucky it will be 5/8 tube.
They also liked to use BESA boxes to save on copper cable and neatly plastered over or a wall is built covering up more than half the buried box on the ceiling (just above a switch drop).
The conduits often just terminated behind a fusebox - which could easily be buried in the wall and double pole fusing.
OK, I'm just unlucky!
Norman
 27 February 2014 02:33 PM
tomgunn
I feel very confident that it will be proper conduit. the thing is that the wiring will almost certainly be old VIR cable and its sticky after that amount of time.
What to do, and remember it 2 plate wiring and not 3 plate for the lighting, is try and pull out each cable leaving one cable left behind... if you cannot shift the cables singularly then make sure you get a good joint and connect some 4mm singles to one end and its best to have someone the other end and start pulling one end and the other chap is 'feeding' from his side.
Pull the wires out and then do a real good jointing, (spacing each cable down the joint from the first one etc), put some lard / tallow etc on the new cables and one feeds while the other pulls in unison - take care - go slowly and jobs a goodun! The 6mm can be a bit of a bugger but you'll be fine! Plenty of tallow / lard!!
Good luck!
Tom
Tom.... (The TERMINATOR).
handyTRADESMAN ... haha
Castle Builders
 27 February 2014 03:33 PM
redtoblackblewtopieces
Yellow 77 might be a better bet Tom.
Kevin
Safety through a Standard
 27 February 2014 03:48 PM
tomgunn
Hi, not heard of that one.
Tom
Castle Builders
 27 February 2014 05:18 PM
Someone will be suggesting washing up liquid next
 27 February 2014 06:51 PM
Someone will be suggesting washing up liquid next [IMG][/IMG]
Only if it's mild, green Fairy Liquid, Andy -
 27 February 2014 06:55 PM
Tom
Try here
Good stuff, but you can't use it for a Ulster fry
 27 February 2014 09:45 PM
tomgunn
Tom
Try here
Good stuff, but you can't use it for a Ulster fry [IMG][/IMG]
Hahaha... wot next? And... wots wrong with washing up liquid may I ask?? Haha!
Nah... give me some good olde tallow!
Tom...
Castle Builders
 28 February 2014 04:51 AM
MrP
Tommy
Wot's wrong with washing up liquid
In a previous life we did a shed for a packaging company utilising 20/25mm gal conduit and singles. In the shed was boxes and boxes of washing up liquid so the guys used a little of what was on hand to ease the installation of the singles all was well good job finished and paid.
Six months later I got a call from the site manager big problem with the distribution board that we had installed. Over time the washing up liquid had worked its way back down the conduit into the board, shorting out the breakers not enough to pop the breaker but enough to cause heat, with the individual breakers melted into one mass of distorted plastic mess. We were very very fortunate.
The reason why the packaging company had a new shed built was that the previous one had burnt down.
MrP day ten eighteen days to go
 28 February 2014 09:57 AM
tomgunn
Originally posted by: MrP
Tommy
Hahaha - sorry! Fair point! I am trying to remember if I did use washing up liquid? I cant say I did or not - but either way, haha, I will def not in the future!
In 1981, (Diana got married?), I was wiring huge houses on price work, three of them and two others to finish off. We laid our T&E's in the boxed flooring thing that was provided and then all finished. Sometime later I had a call that our cables were decomposing, (a bit like Johann Sebastian Bach I guess), as when the builders finished off the houses they filled these boxed trenches set in the floor with shredded polystyrene granules and what was happening was the polystyrene was actually eating the PVC sheath away! Also be careful when wiring in the rafters that have polystyrene for insulation purposes!
Keep clean out there! Haha!
Tom
Castle Builders
IET » Wiring and the regulations » Rewiring lighting in old conduit
