Topic Title: extractor fan requirement
Created On: 21 January 2014 03:26 PM
goldenboy1818
Hi I just wanted to check something. Going through a rewire and in the upstairs bathroom there is currently no extractor fan just a large window. Client is adament he does not want one installed while the rewire is going on. I take it this is ok as im not making the installation any worse than it already was ?
Thank you
 21 January 2014 03:30 PM
aligarjon
if its an existing bathroom there is no requirement. if its a new bathroom there would be.
Gary
 21 January 2014 03:47 PM
goldenboy1818
thats what u thought, thank you
 21 January 2014 07:49 PM
Grumpy
Gary
Hi Gary,
My understanding is that if there is an opening window then no extractor fan is required. Is this now wrong?
Grumpy
 21 January 2014 08:04 PM
Gary
Hi Gary,
Grumpy
For existing, or no matrial change of use, then that's fine.
For new build, or a new bathroom in an existingbuilding (say new en suite for example) then itshould have ventilation in accordance with any of the methods in Approved Document F - one of which is natural stack ventilation amongst other mechanical ventilation approaches. Basically it has to shift 15l's from the wet area
A simple opening window won't comply these days
 21 January 2014 10:16 PM
aligarjon
Gary
Hi Gary,
Grumpy
It used to be if it was just a W/C then an opening window would be acceptable. I don't think that has changed.
Gary
 22 January 2014 04:34 PM
Grumpy
Ah! Thanking you. All this "used to be" is starting to make feel old!
 23 January 2014 09:20 AM
Grandfortune
Trying to find where i read it but i think even a W/C now has to have extraction
Cheers
|Grand
 23 January 2014 10:07 AM
burn
Building Regs Part F cover ventilation. Available free on the planning portal of the government website.
burn
 23 January 2014 11:38 AM
Parsley
You need ventilation in a new build WC sanitary accommodation or where a new sanitary accommodation is provided.
6 l/s is required.
