Topic Title: what boxes ??
Created On: 06 December 2013 08:12 AM
goldenboy1818
Hi if its a larve and plaster wall what boxes do you normally fix in ?? surface boxes ??
 06 December 2013 08:16 AM
geov
Hi, for lathe & plaster, you can sometimes get away with a fastfix box or a deep metal back box. If the latter, I usually place a piece of dpc behind the box to avoid any dampness. But be mindful of the damage you can cause to the plaster when cutting through - I use my Fein for this.
 06 December 2013 08:43 AM
tomgunn
TBH, the best way is to make a hole / other and fix a noggin... or aim for one of the upright or diagonal beams.
regards... Tom
Tom.... (The TERMINATOR).
handyTRADESMAN ... haha
Castle Builders
 06 December 2013 08:44 AM
normcall
Think of it as cutting through the structure and then walk away, remove the lathe & plaster then plasterboard and replaster or suggest an alternative.
Norman
 06 December 2013 09:13 AM
unshockable
I agree about the Multitool although I use the Bosch with £3 blades. I draw a line on the centre of the box height and drill with a 5mm hss every inch to find the upright. Pencil line around a metal box and cut with an old blade(its very abrasive).
When you get to the lathe, pin them down to the upright with penny washers and change to a sharp blade, scalloping out the member too if necessary.
IMHO
Simon
 06 December 2013 05:07 PM
BrucieBonus
If it's just for a light switch and you very carefully cut with a multimaster (or similar), then you can often get away with using a 45mm deep plasterboard box as the wings will sit behind the lathes.
Once really impressed a customer by fitting her new switch with NO damage as I was able to lift the floorboards above and drop the cable into the void.... doesn't happen that often, eh!
Not suitable for a socket though
 06 December 2013 08:27 PM
aligarjon
I give the customer the choice. surface box or be prepared for some damaged plaster. You will probably struggle with fasta fix because of the varying depths of the lathes as they are often twisted a bit and can be a fair way back for the clamp. If it is for socket boxes try to find an upright and use a metal box, but still be prepared for potential repairs.
Gary
 07 December 2013 08:14 AM
dickllewellyn
Also if it's sockets, be prepared for the bottom 10-12" of the cavity being packed full of muck!
Richard (Dick)
 07 December 2013 07:30 PM
jcm256
Don't destroy old horsehair plaster and lime by cutting out box holes, you are cutting out history. Make a nice feature use surface wooden batten and wooden block for the switches. Alternatively, poke a small terminal screwdriver find the gap between the laths make a small hole and solid fish wire up the cavity, to hook on the other fish wire fed in from the top. Wear facemask protection.
http://www.askmehelpdesk.com/i...t-bad-you-512824.html
http://www.google.co.uk/search...QsAQ&biw=1008&bih=577
There use to be another type of stud wall and ceiling board made out of pressed straw and cement; you could not chase it, as it was only about 1½" thick, resort to ceiling switches that's was the only way to proceed.
Used to spread cow dung on walls with a yard brush to make plaster stick that was before mortar mix, very effective especially in plastering outside walls on farmyards
sheds. So give a thought what you bore holes in.
 07 December 2013 09:12 PM
perspicacious
Even more fun if you find that all the stud walls and ceilings are expanded mesh that has been rendered with what appeared to be a 4 to 1 mix of fine concrete....... Serves me right for trespassing into Bristol city
BOD
