Topic Title: 16mm t&e supplying house,main protective bonding?
Created On: 02 November 2013 02:43 PM
hertzal123
A customer has requested a cu change in the above house.The t & e
is on a overhead from a detached building.The supply is tns.If I use the equation to prove the cpc is adequate,can the 6mm cpc in the cable be used for main bonding.I think the switch fuse at the supply is
a 63A bs88.Thanks for any advice.
Hz.
 02 November 2013 06:49 PM
24Hour
Whats the short circuit current , or zs at db?
Whith this info u can work out withstand
Yes i do do 24/7 everyday of the FLAMIN year.
 02 November 2013 11:37 PM
hertzal123
Hi 24hr,
Will find out on Monday;
Thanx.
 03 November 2013 03:43 PM
24Hour
I just re read your question, if you are usung the 6mm in the t+e then u need to run a seperate earth 10mm.
If no bonding is req then the 6mm should be ok but subject to adiabatic equation of course.
It maybe cheaper/better to add a plastic insert if its water you need bonding.
 04 November 2013 08:32 AM
hertzal123
Just thought the 6mm cpc in the submain was large enough fo mpb
if the supply was tns,but maybe not.
Regards,Hz.
 04 November 2013 12:20 PM
What's the (required) size of the overall installation's earthing conductor? - i.e. on what supplies the 63A fuse from the DNO's kit. Main bonding sizes should be referred to that.
 04 November 2013 01:52 PM
Parsley
As Andy as stated the bonding conductors will need to be sized with reference to the earthing conductor. the bonding conductor CSA must be at least half of the earthing conductors required CSA, 6mm is the minimum allowable CSA for a non PME installation bonding conductor.
The DNO's will probably want a minimum of 10mm2, UKPN consider TNS as being PME anyway.
 05 November 2013 07:15 PM
hertzal123
The switch fuse has a 10mm earth lead,but I am going to suggest a new 25mm overhead swa and 80A/100A fuse,,since the customer now wants a 10kw shower!
Thanks for all the advice,
Hz.
 06 November 2013 07:24 PM
lyledunn
So you are going to rip it out? Not if it was my house, I have my golf club fees due and even if I hadn't I have better things to do with my money. How is that for a well considered engineering judgement?
Lyle Dunn
 06 November 2013 08:22 PM
golf club fees
Waste of a good walk, Lyle - but I agree that ditching a 16mm2 T&E submain in a domestic property is just a tad brutal in terms of a solution
Based on the OP comments, it sounds compliant with BS 7671 to me
 06 November 2013 09:37 PM
Fm
Likewise dont see the attraction
