Topic Title: Strange Fault
Topic Summary: Tripping
Created On: 29 October 2013 06:58 PM
Ampman
Evening ,
Had a call out to investigate downstairs lights tripping , rcbo goes off when lights turned on .
This happens from anywhere on the circuit so when a load is put on circuit it trips ?
I meggar tested circuit live neutral joined together to earth , that shows dead short , Why does the rcbo stay on but only trip when load is on ?
There are dimmers on circuit ?
I put wiring into another rcbo to prove i didnt have a faulty one .
Weird ?
anybody had similar .
I explained to customer that i will have to strip everything down to find fault
cheers
 29 October 2013 07:04 PM
You did remove the neutral from the neutral bar when you tested I suppose?
 29 October 2013 07:11 PM
Ampman
Yes removed from rcbo completely
strange one
 29 October 2013 07:18 PM
Not teaching you to suck eggs Ampman but was it really a dead short or something like 0.01 meg? It's easy to think there's a dead short and confuse yourself when on the ins. range of the meter!
 29 October 2013 07:30 PM
Ampman
0
it read on meter
 29 October 2013 07:33 PM
0 megohms maybe!
 29 October 2013 07:37 PM
Ampman
yes megohms ,
tested at 250 volts to avoid damage
 29 October 2013 07:44 PM
All i'm trying to say Ampman is that 0 megohms isn't necessarily a dead short, it could still be quite a few hundred k-ohms.
Have you tried measuring N-E and L-E? I find that testing L+N-E doesn't always give helpful results.
Edited: 29 October 2013 at 07:55 PM by daveparry1
 29 October 2013 08:19 PM
Banners
Has to be a neutral to earth fault - current returning to RCBO = trip perhaps earth tied to a copper pipe etc. so (sufficient) fault current not coming down earth to trip RCBO.
 29 October 2013 09:02 PM
Ampman
Dave ,
I will test L-E , N-E , when i return , to be honest it was 6 ish when i left too late to start stripping it all down .
Banners cheers
See it being a ball ache ,
 29 October 2013 09:21 PM
Ampman, as banners says, it a neutral to earth fault. The imbalance is only detected by the rcd when a load is applied.
