Topic Title: 110v installation
Created On: 19 October 2013 03:56 PM
aweightman
I've been asked at work to install 5 110v wall mounted sockets do I need to install a transformer in the fuseboard or is a wall mounted transformer better then wiring the sockets from that, if so wots the best equipment to use.
cheers andrew
 20 October 2013 02:00 PM
hertzal123
cheers andrew
Hi Andrew,
Doubt you would fit tranny in a db.In the past,I have used a legrand transformer in a wall mounted cabinet from RS.Or you could have one
made up by a manufacturer.
Regards,Hz
 20 October 2013 06:07 PM
OldSparky
dont forget to use DP mcbs...
 20 October 2013 08:35 PM
hertzal123
And type C or D if primary supplied from an mcb.
Hz.
 21 October 2013 10:48 AM
You could consider sockets with integral transformers ?
Something like these
 21 October 2013 10:12 PM
MrOther
Anything 11ov I would recommend Blakey. They supply most temp firms.
 22 October 2013 02:00 PM
I'll get you for that, Butler
 22 October 2013 02:06 PM
will they be on a common bus then?
 22 October 2013 06:28 PM
LoL - sorry about that Andy - this could go on for hours now
 22 October 2013 07:46 PM
Zuiko
Reminds me of when I worked in Africa at a rural hospital.
The hospital was kindly donated two blood cleaning machines from the United States. The machines were rated at 110V, the local supply, 230V. The simple solution was to power them in series.
Not saying that's got anything to do with a working solution for you; it just reminded me
 30 October 2013 06:02 PM
HarryJMacdonald
A word of warning about % volt drop. It will be 4 times larger at 110V than 230 so if the dist board is some distance away you might need larger cabling.
