Topic Title: stuck
Created On: 24 September 2013 08:47 PM
OldSparky
hello peeps
i will try to keep this short and to the point
kitchen in a restaurant..
called out to investigate problem with extract system tripping out, couldnt find fault but did change the controller for the gas valve.
this was a month ago.
Called out today same problem with reported sparks coming from the fused spurs suppling the extract fans, also the bar ring had tripped, and a 3 phase oven on an other board.
again nothing found, on way home they rang to say lights were flickering and sparks coming from spurs again, and the bar ring had tripped..
they closed the restaurant
the only thing that happened the first time this happened western power were working in the street and knocked a few businesses out.
i am thinking a loose neutral, i would like your thoughts if possible
many thanks
Paul
 24 September 2013 08:54 PM
michaelbrett
Sounds like a poor or no neutral causing increased supply volts.
Voltage measurements at the supply terminals of the CU or DB will confirm if the fault is still there?
Sounds like a lot of possible damage to equipment and accessories.
Mike
 24 September 2013 08:56 PM
Almost certainly a neutral going open circuit - stick a voltmeter on it and get some load on - or do a L-N loop test at 25A - I'll bet it's wandering all over the shop - telling you that neural is about to go AWOL with all the usual fun and ganes that brings
 24 September 2013 09:21 PM
Legh
I can understand that lights flickering and rfcs going off line suggests a loose neutral somewhere, but sparks coming out of the sfcu's ?
I assume that these were all checked for tight / clean connections?
Legh
de-avatared
 24 September 2013 09:59 PM
OldSparky
Legh
sparks out of the fuse carrier on the spur, the fan is only about 10amp
had it running for an hour before i left
OldSparky
i am looking forward to tomorrow...
 24 September 2013 10:06 PM
Definitely an open or partially open neutral either at the incoming point or supply to the building. Same as OMS says, measure phase to neutral with a load applied. You will be getting between 230 - 400 volts fluctuating.
 24 September 2013 10:07 PM
OldSparky
thanks guys will let you know tomorrow night
 27 September 2013 08:14 PM
OldSparky
ok peeps
no loose neutral on the site,
only 2 things i can think it was,, a phase off or worse case a loose neutral but it must have been from the supply..
fitting a monitor for two weeks just in case it happens again
 27 September 2013 08:19 PM
Almost certainly a supply side problem if everything looks OK your side
 29 September 2013 04:32 PM
stateit
A bad crimp joint on overhead line caused this in a property near me. Infuriating to pin down.
S George
http://www.sg-electrical.com
 30 September 2013 02:36 PM
Sparks coming from fused spur units suggests to me that a significant voltage existed between the CPC connected to the fused spur and some adjacent metal work at true earth. (and lack of effective bonding)
An open/partialy open PME conductor could do that, consider say 50 volts between the PME earth and true earth. Metal clad fused spur at 50 volts above true earth, and touching gas or water pipes or structural steel work that is at true earth.
Severe fire and electric shock risk.
An alternative explanation would a lack of an effective earth to the consumers installation.
Phase to earth fault raises voltage on CPC far above true earth, and the voltage difference between CPC and metalwork causes sparking, also very dangerous.
