Topic Title: TV signal
Created On: 11 September 2013 07:26 PM
OldSparky
hello peeps,
will try to keep this short..
my tv at home has stopped receiving free view, meaning it keeps pix elating.
so checked the signal, its way to high because the quality is 0,
reduced the signal strength but the quality is still poor.
oh and all the other tvs in the house work fine.
things i have tried,
cable direct from the aerial
replaced all cables behind tv
fitted an attenuator
re boot the tv
re tuned the tv
checked for 4g interference
now i am stuck, has anyone any ideas because its driving me nuts.
cheers
Paul
 11 September 2013 07:39 PM
It's probably interference from the new G4 telephone network which uses similar frequencies to Freeview. You'll need a G4 filter, had the same problem myself a few weeks ago. Look on Ebay for G4 filter, about a tenner,
 11 September 2013 07:52 PM
weirdbeard
Have you tried the non working tv plugged into one of the 'known to be working' points?
 11 September 2013 08:05 PM
OldSparky
dave... no 4g where i live, ( AS FAR AS I KNOW)
weired... no but, but run a cable direct from the aerial.. and still has same problem..
the tv has a input meter, the quality goes from 0... to 36 % up and down, its not steady
 11 September 2013 08:18 PM
Rulland
Had a fellow question me about exactly the same thing today, pixelation etc, a so called tv man fitted amps and a new aerial but it's not particularly better, this chap lives on Anglesey, don't know if 4g is there yet.
Anyone got any more info on the 4g problems/symptoms?, recommendations?.
 11 September 2013 08:26 PM
weirdbeard
Without knowing your known working tvs distribution set up, unless your non working TV is huge and can't be moved I'd suggest at least trying it in one of the existing known working points, even if by a made up long extension cable.
 11 September 2013 08:47 PM
OldSparky
appreciate that
will do that tomorrow with a lead..
i suppose 4 g might be on but being tested,
according to the web map its not here in cornwall yet
 11 September 2013 08:58 PM
weirdbeard
here in cornwall
I've a booking in that town next week for a few days, let me know if you need a hand
 11 September 2013 09:02 PM
Rulland
Nor on Anglesey, but hey, they tell us the truth don't they?.
 11 September 2013 09:38 PM
michaelbrett
If you think that you may have 4G interference, take a look at this website:
https://at800.tv/?utm_expid=68052535-0.7RPj2h84S0-qrBVPv8Q5dA.0&utm_referrer=http%3A%2F%2Fsearch.aol.co.uk%2Faol%2Fsearch%3Fs_chn%3Dhp%26enabled_terms%3D%26s_it%3Daoluk-homePage50.a%26q%3Dat800tv
It may help you.
Edit: Good grief - what a long address. If it does not work the website is called at800.tv
Mike
 11 September 2013 10:27 PM
OldSparky
mike, i looked at that site, waste of time i couldnt find out the 4g map,,
i get the feeling this 4g might be a step to far, being a conspiracy theorist ...
It may help you.
Mike
OldSparky
here in cornwall
you will pass my house, i live in launceston
 12 September 2013 12:02 AM
westfield6
The whole 4G thing has been blown out of all proportion by hacks who know nothing about the subject.
Tests have shown that interference is extremely unlikely unless you have a masthead amplifier and live in close proximity to a 4G mast.
You don't need to buy a filter either, one will be provided free of charge to affected households by AT800.
 12 September 2013 07:16 AM
normcall
Aerial and leads are most likely cause.
Check http://www.ukfree.tv/starthere.php or similar also that work is not being carried out on your local transmitter.
Just another thing, they are still turning off transmitters, adding, removing or just changing multiplex.
Try a retune!
As my wife says " we never had this problem in the old days!!"
Norman
 12 September 2013 09:10 AM
bartonp
Retune.
Try search/posting here:
Linky
 12 September 2013 09:48 AM
northernlights
Whilst not suffering from pixelation my main TV has suddenly developed a habit of switching itself on during the night.
The only change to things is a local taxi firm have installed a huge co-linear aerial on top of a 20ft mast about 100ft away from my TV aerial. Not knowing enough about infra-red I can't say for certain that the transmissions from the firms radio is somehow affecting the remote of the TV. The other two TV's in the house are unaffected.
 12 September 2013 02:08 PM
normcall
Ours does/did that.
I think it was due to the attached PVR switching on to check for OTA updates.
I gave both a good talking to, told them to do nuffin automatically and it's still sulking 2 months later!
Why 3am in the morning??
Norman
 12 September 2013 05:51 PM
"Why 3am in the morning??"
Because there`s no such thing as 3am in the afternoon , Norman!
 17 September 2013 06:36 PM
OldSparky
ok done this so far..
fitted variable attenuator, fitted 4g filter, ran cable from other tv points, ran cable direct from aerial, disconnected cables via sky box.
all cables double screened, all other tvs fine..
signal 100% quality 0%
if i put the attenuator on and reduce the signal it rises to about 30% then drops down then up again, does this continually.
i am at a loss and it now doing my head in so any advice would help..
oh the aerial guys around here are thick as pig s*%$ so dont ask me to ask them for help.
Paul
 17 September 2013 06:48 PM
Have you tried this set in another room or tried another set in this room? I'd be starting to suspect a tuner fault now. You have tried a re-scan I take it?
IET » Wiring and the regulations » TV signal
