Topic Title: Off topic again, laser levels
Topic Summary: Any recommendations?
Created On: 04 September 2013 08:17 PM
Grumpy
Following on from previous post finally plumped for a Dewalt 18v impact driver. Thanks for all your input.
Being a bit old school I've used a water level in the past with some success but they can be a bit irritating - bubbles, sidekick puts his end down without cap and water runs out etc - so I wondered about laser levels. Are they any cop? Are they accurate enough? Immediate need is a loft conversion and I have to get three padstones vaguely on a level. I can also try to justify the expense for lining up kitchen sockets . . . . . blah blah! Or should I stick with the Egyptian water level (don't forget that they built the pyramids with boning rods, no theodolites then eh?).
Would appreciate your experiences.
Thanks.
 04 September 2013 08:31 PM
peteTLM
PLS180 all the way. sockets, dado trunking, suspended lights, containment etc
 04 September 2013 08:51 PM
perspicacious
" so I wondered about laser levels. Are they any cop? Are they accurate enough?"
You just need to remember that a water level will follow the Earth's curvature and a laser level puts out a straight line
BOD
 04 September 2013 08:55 PM
Grumpy
Yeah. Fortunately the lofts and kitchens I do aren't that big!
BOD
 04 September 2013 08:58 PM
Grumpy
Thanks Pete. Any particular reason?
 04 September 2013 09:16 PM
peteTLM
Its the size of a 2 pole main switch. Magnetic or hole fixing on the mounting bracket. Self levels instantly.
will do horizontal or vertical 'loops' around the building. Put it in the corner of a room and it will do 360' all around.
Will go 15m+ across a warehouse in lowish light or from memory 8m in daylight.
Comes with lots of padding and a case
 04 September 2013 09:26 PM
kirchoffs
I've had the Dwalt DW087K self levling, with an amazingly strong magnet. I've had no problems so far (about three years old now).
Edited: 04 September 2013 at 09:42 PM by kirchoffs
