Topic Title: SKY TV question
Topic Summary: What cables do i need to the tv
Created On: 27 July 2013 08:22 PM
aligarjon
A quick question for anyone in the know.
I am thinking of getting sky tv at home. I want to have the sky box remote to the tv, can i get away with just a digi coax to the tv from the sky box or do i need a scart lead as well. ( The coax is already there from where i want to fit the sky box) and ive got a wooden floor down across the room so would be a bit messy trying to get a scart there as well. Also the tv is up on the wall.
I pressume i need 2 cables out to the dish for the sky + from the box ? is that correct, as i would do that before they arrived. Also do i have to have a bt point available, i seem to remember you used to.
Gary
 27 July 2013 08:57 PM
sparkiemike
I think the cable between the TV and sky box will be HDMI. SCART is pretty much old/obsolete technology.
You should also think about other video sources as they may need their own HDMI cable, eg. DVD/Blue-Ray Player, Games Console, unless you are going to use some kind of video receiver.
EDIT
If a false wall or chasing is not an option, some d-line trunking might hide the cables - it looks OK
 27 July 2013 09:02 PM
Rulland
Sky+ and hd require at least two feeds from dish to box to allow record and play at the same time.
You will need a scart preferably as opposed to a coax, although a hdmi is more the norm between box and tv these days.
Coax is worst, scart next, hdmi best as far as quality is concerned.
 27 July 2013 09:04 PM
Rulland
I use an AV receiver, all inputs go to that and just one output to tv.
 27 July 2013 09:06 PM
peteTLM
the sky box needs a phone line to the outside world, 2 sat cables to the dish, and ideally an ethernet connection to the internet router (this allows sky on demand and stuff like that.) Having an internet connection is desirable at the tv as well as this allows netfliks etc, 4OD, BBC Iplayer if you have a 'smart' TV.
what you run between the tv and the sky box really depends on what the TV is, and has available. Typically, a HDMI cable would cover most things, altough S video is a possibility, and bringing up the rear would be a scart lead. (composite video and RGB may make an appearance)
Reliying on a coax between the TV and sky output is probably the most crap transmission method here.
Whats avilable on the back of your TV then?
The remote eye to control the sky box from somewhere else piggy backs its signal over coax to the RF2 output on the skybox.
 27 July 2013 09:24 PM
M.Joshi
If you cannot run a channel or trunking from the TV, you should plan for the maximum number of HDMI, RCA and Ethernet cables to the TV to cover all eventualities.
If you have an older DVD player or video recorder then you may also need to run a SCART lead too.
It's always best to have cables for all eventualities otherwise you may end up with cables hanging from the side of the TV! Some games consoles require RCA connectors.
If you are thinking of also purchasing an A/V receiver, it will have an HDMI switch built-in so you may be able to get away with just one HDMI cable and perhaps an Ethernet cable (depending on your model of TV).
 27 July 2013 10:57 PM
aligarjon
Thanks guys. I do have a built in cupboard behind the tv, i might be able to fish a couple of coax cables across to it from outside and put the sky box in there. Will all the functions work through the magic eye or just basic channel change. An ethernet cable is do-able from the other room with a bit more fishing.
Gary
 27 July 2013 11:48 PM
M.Joshi
You will need HDMI cables as coax will not carry high-definition signals to the TV. The HDMI connectors are much smaller in comparison to SCART.
 28 July 2013 08:28 PM
Martynduerden
You can use whatever cables you like, HD can be sent over cat5/6 or coax nowadays.
As others have said you need 2 ct10 / rg6 or similar to the dish per skybox and a telephone line for On demand / interactive services
if you have an existing coax network everywhere just use that if new cables are an issue.
Martyn.
 28 July 2013 08:38 PM
M.Joshi
If you send the HD signal over Coax or Ethernet, converter boxes are required at both ends. The picture quality won't be as good as a direct HDMI connection with an HDMI cable between the Sky box and TV.
