Topic Title: Megger VF2 Volt stick
Topic Summary: Died?
Created On: 23 July 2013 01:03 PM
SherlockOhms
Volt stick did an odd thing today.
When held against a known supply it pulsed/flashed steadilly.
I assumed batteries? Swapped them for new but now it's dead?
Is it scrap?
S.
 23 July 2013 01:23 PM
bartonp
Batteries were low, and now the new ones are in back to front?
 23 July 2013 01:52 PM
SherlockOhms
Even i'm not that daft.......but I'll check
 23 July 2013 04:38 PM
Grumpy
And the outcome of that check Sherlock . . . ?
 23 July 2013 07:53 PM
Rulland
Batteries right way up but voltstick upside down.........
 23 July 2013 07:58 PM
M.Joshi
Is it scrap?
S.
Did you use good quality alkaline batteries or cheap £1 ones?
 23 July 2013 08:13 PM
Thripster
Have you tested the 'new' batteries with your approved voltage tester yet? Did you use a proving unit to test the tester first? Did you test the batteries of the proving unit?
 24 July 2013 07:41 AM
SherlockOhms
I've tried all combo's of the batteries/stick. I did get a brief repeat of the pulsing effect.
I've concluded that I'm probably stupid, oh, and I need a new stick.
S.
 24 July 2013 02:13 PM
M.Joshi
The Sagab ones are supposed to be the best VoltSticks :
http://www.voltstick.co.uk/ima...voltstickShortform.pdf
This video shows how the different ones work:
http://www.youtube.com/watch?v=pplWPhBozh8
As I'm sure you know, Voltsticks should only be used as an indicator.
 24 July 2013 06:50 PM
Grumpy
'S funny they came as standard on my van. What are you driving?
 25 July 2013 06:38 PM
stateit
Pull the spring contacts for the batteries out a bit ?
If that doesn't help then I'd just take it apart to see how it works
[edit] And Oh... I prefer the Fluke ones myself [/edit]
S George
http://www.sg-electrical.com
 25 July 2013 10:16 PM
A man after my own heart!
Although I always thought afterwards I would have been better taking it apart while it was still working to really see how is was supposed to work properly!
 25 July 2013 10:48 PM
Zs
Nooooo. Once it has failed once you must throw it away. Sherlock, you are worth much more than a 15 quid volt stick. Use it as a door-wedge or something. Get a new one.
Zs
