Topic Title: Downlighter halos
Created On: 08 July 2013 06:24 PM
Pacific
I am replacing 30 existing downlighters with GU10 LED fittings supplied by customer, the existing holes are approx 10mm too big, I have heard of converter kits but the all seem to include the lampholder etc, what I was envisaging is similar to the halos we used to fit on ceiling roses but having trouble finding anything. Any ideas?
 08 July 2013 06:37 PM
JZN
What make are the downlights? I know that Aurora make some specifically to fit their downlights, but they would not necessarily work with other manufacturers products.
John
 08 July 2013 06:43 PM
peteTLM
are the existing ones MR16 or similar? At 30 to deal with, id hunt high and low to try and get a new fitting that will fill the existing hole rather than put up with whatever the customer has found until ive run out of options.
What size hole do you have at the moment?
 08 July 2013 08:06 PM
sparkiemike
As the customer supplied the new fittings I would say it is the customer's problem.
Dave69
try searching for this Aurora AU-FRLAPMW
is that what you mean? our local edds have them for a few quid each
 08 July 2013 09:07 PM
 08 July 2013 09:47 PM
Pacific
The fittings are KSR 104mm outer dia with 94mm cutout, existing holes 100mm give or take
 08 July 2013 09:53 PM
Cremeegg
Halers do a metal converter plate which fits their products and is available to purchase separately - about £9 each from memory.
Pacific
One of my best customers, does not mind paying for my hassle
 09 July 2013 02:01 PM
Pacific
Thanks for all your input, should be able to find a solution form those ideas
 17 July 2013 03:59 PM
Pacific
After searching for halos, we decided to have some made from 3mm plastic by a local signmaker, although they are square they look ok, where there's a will there's a way
