Topic Title: running cables behind external render ?
Topic Summary: safe zones ?
Created On: 06 July 2013 02:54 PM
aligarjon
I have a customer that wants me to run cabling around an external wall to external lights before the walls are rendered. I can run the cable in the equivalent of the internal safe zones. (through from switch and strait up to light 1 then horizontally to next light) is this permitted ? I am struggling to find anything in the regs either way other than it feels rough . I would be tempted to do it with swa but that would be a nightmare to terminate and conduit probably too deep which leaves me T+E behind betal capping or in oval ducting. The circuit is rcd protected. The bedrooms have the dreaded laminate flooring .
Gary
 06 July 2013 04:13 PM
I don't see why not, the permitted zones are not specified as being internal only are they. As a matter of interest, why did you mention metal capping? I suppose it would give a bit more protection from the renderers's trowel but i'm just checking that you don't think it will be any more compliant than plastic,
 06 July 2013 04:45 PM
geoffsd
Accessories on the other side of the wall only count if the wall is 100mm. thick or less.
Can't earthed metallic sheath cable be used?
 06 July 2013 05:07 PM
peteTLM
BS8436 cable
 06 July 2013 05:40 PM
Geoffsd, I don't think the accessories will be on the other side of the wall? Th op is talking about external lights with external cabling,
 06 July 2013 06:49 PM
perspicacious
Would installing YT1 mini-trunking for the plasterer to render flush up to either side of it so that it remains obvious, be acceptable?
BOD
 06 July 2013 07:13 PM
geoffsd
Originally posted by: daveparry1
Geoffsd, I don't think the accessories will be on the other side of the wall? The op is talking about external lights with external cabling,
Yes, you're right - Sorry.
Misread 'through from switch and straight up (to light 1)'
 06 July 2013 09:46 PM
jcm256
Install pvc cable on an outside wall then plaster over, it might be a small point , but you will want to consider penetrating damp, big fluxions in temperature, trellis or lattice drilled screwed or nailed to the outside wall, degeneration of cables in contact with cement, (although they say modern PVC cables not affected as much as older cables). I would say get a bit of pyro or guardian Ali-Tube/LSZH Cable BS8436 and the chances that this install will be less open to degeneration.
(What ever happened to the rule you must be able to withdrawn cables from containment for future renewal).
 06 July 2013 10:41 PM
aligarjon
thanks for the replies guys.
I think there might be a problem with plastic trunking expanding etc breaking the seal of the render and getting water behind it ?
I know what you mean JCM , they don't seem to worry about it when they dot and dab all these houses and just clip down the walls. its common practice right or wrong.
The capping is just a bit of protection from the trowel as you say Dave.
I think i'm going to turn this one down though, it just seems really rough to me.
Gary
