Topic Title: SELV LED lighting circuit
Topic Summary: Preferred cable type
Created On: 19 June 2013 08:42 AM
davebp
Hi all,
Thinking about installing some LED dimmers like these:
LED dimmer unit
So, I'd use one 12V LED driver to feed several of these units, which would then feed LED tape / spots in a kitchen, - wiring all plastered in.
Would you use standard twin & earth, keeping the CPC electrically separate from all fittings and the secondary side of the PSU, - this would be cheapest and provide the option of returning the wiring to LV if preferred at some point in the future.
Or would it be better to use a different cable type to identify the wiring as being different from the LV wiring? - Also, as it would be a DC system, is there a requirement to sleeve conductors of whichever cable is used in brown / grey as per table 51?
Thanks,
 19 June 2013 08:55 AM
I normally use twin flex, do not see the need for anything more elaborate at the low voltages and currents innvolved.
I would avoid any flex or cable with a CPC as this gives more oportunity for future doubt or confusion (to what should it be connected, or if not connected, what to do with it)
Most of the LED drivers that I use come complete with a length of twin flex for the output, suggesting to me that if this is not long enough, that it would be reasonable to extend it with similar material.
Strictly speaking, if blue/brown insulated twin flex is used, then the blue core should be sleeved grey to denote the fact that this is an unearthed or floating system without an earthed neutral.
I must admit though that I dont bother, and have NEVER seen this done.
 19 June 2013 09:44 AM
normcall
I installed a lot of the 24V strips under the wall units in my new kitchen to replace the original florescent tubes.
Made up a board and brought the original supply into a joint box to feed 3 * 36W 24v transformers. Wired 3 supplies down behind the wall cupboards with the transformer end terminating in a J601 (allowed 3 separate 24V supplies), used automotive 2mm twin cable, at cupboard end used a chocbox to change from the 2mm to the 'flying lead' to the strips.
Had to replace all but 2 of the plugs, so not impressed with quality but works well.
One little quirk, the capacitance of the different length cables (and different loads) means each set of strips 'die' at different times when switched off!
By the way, the transformer board is in the loft as I live in a bungalow.
Norman
 19 June 2013 12:32 PM
dickllewellyn
I tend to use twin flex and solder direct to the strips if I can.... Not always possible due to the nature of the job though, so then it's a case of finding somewhere to stash a joint.
Richard (Dick)
 19 June 2013 12:55 PM
BigRed
2 core yy works well, tough sheath, good for teh cable glands too being round in construction. I steer clear of broun blue to avoud confusion with 240 v stuff
 19 June 2013 01:51 PM
Zs
I blame the education system myself
Table 51 on page 116, at the bottom... it's a list of acceptable colours for this circuit. So long you'd be forgiven for thinking Dulux wrote it.
Zs
Edited: 19 June 2013 at 02:01 PM by Zs
 19 June 2013 05:50 PM
M.Joshi
Originally posted by: davebp
So, I'd use one 12V LED driver to feed several of these units, ...
Just check first with the manufacturer that multiple dimmers can be connected to the same transformer. Also ensure you choose a transformer that slightly exceeds the power requirement of all the LED lamps/strips together should they want to install higher wattage spots at a later stage.
 20 June 2013 01:31 PM
davebp
Cheers all,
flex or YY it is then. - 4-core YY if i end up going red green and blue!
