Topic Title: Segregation
Topic Summary: Emergency Lighting
Created On: 17 May 2013 05:19 PM
mrcornbeef
Hi
Any of you guys installed an addressable emergency light system, after views on segregation of the mains supply and the specified data cable which links fittings to panel the data cable is Beldon 8471 my concern is the keeping beldon away from the mains is it a major problem with interference etc any input welcome
 17 May 2013 08:55 PM
GB
It would be best to speak to the lighting manufacturer for details although I guess seperation by 50mm will be sufficient. (although 100mm may be prudent) I guess as the cabling all goes to the same point anyway there is little little interference from the emergency power and data but there will be other power cables to consider.
 17 May 2013 11:49 PM
Legh
As far as I know that if the emergency lighting cabling is not contained within the fitting then it must be segregated by a earthed screen capable of withstanding a fault current from other circuits.
Legh
de-avatared
