Topic Title: Off Topic
Topic Summary: Laptop Batteries
Created On: 11 May 2013 09:30 PM
kirchoffs
Just received a new Lithium Ion laptop battery for my Dell laptop.
To cut a long story short order was duplicated so i now have two batteries and Dell have said keep it.
My question is is it better to keep one in the cupboard as a spare for a couple of years ,does its life start ticking away?, or is it better to use both batteries alternatively changing every week .
Thanks in advance Dominic
 11 May 2013 10:14 PM
keylevel
Leaving one as a spare for a couple of years shouldn't be a problem, but it may be worth giving it a charge every six months or so.
If they go completely flat they can be a pain to get going again. I've got an old Dell which I hadn't used for a few years and it took several hours before the batteries started to charge normally. I'm guessing the charger was very, very 'gentle' until it got some power in to them.
 12 May 2013 08:18 AM
Jaymack
Battery life is reduced for each charge/discharge. It's peferable to keep one as a spare after ensuring a full charge, then replacing at annual intervals say, but dependent on the battery useage, (leaving a laptop continually plugged into the mains, will have a minimum effect on the life of the battery).
 12 May 2013 09:40 AM
One manufacturer I remember recommended keeping a new battery in the fridge until required, (not freezer!)
 12 May 2013 09:45 AM
Things last longer if you keep them in vinegar!
 12 May 2013 09:54 AM
Except chips, ironically enough !!
Nowt worse than soggy chips
from memory, aren't LioN batteries optimised at about 18C, should be stored with about a half charge and topped up and discharged to about 50% every 3 - 4 months and shouldn't be stored when fully flat.
 12 May 2013 09:56 AM
DOUGIE1000
my laptop battery is only put into laptop when taking the laptop somewhere i know there will be no 240v for charger. the rest of the time laptop battery sits in office drawer.
When i do use laptop battery i still can get maybe 3/4 hours on battery
Dougie
Power Plus Electrical.co.uk
 13 May 2013 08:44 PM
kirchoffs
Thanks for all your tips and advice especially ebee,i'm going to try Sarsons .
Regards Dominic
