Topic Title: The DNO and systems of earthing
Created On: 01 May 2013 08:38 PM
Avatar for UKPN.
UKPN
Contrary to popular belief, the DNO has many types of earthing in its
network.
But for purposes of this post I will talk about two=SNE and CNE.
SNE, normally cable sheath, is offered via a clip and earth block on older properties and is there for the consumer to use without obligation
on the DNO. The DNO has no obligation to maintain it.
Many older cables are not an earth path at all, and any exposed sheath
will be shrouded for safety.
CNE, (PME) is provided on new properties and the DNO is under obligation to maintain it subject to being offered in the first place if it comes under the safe installation rule.
The DNO are under no obligation to update a SNE system to PME but
will, if the network is CNE.
The DNO do not guarantee any external loop impedance, consumers/
designers must decide if the values suit their purpose.
Regards.
 01 May 2013 08:55 PM
Avatar for OMS.
Great - so you are saying that any SNE system - usually a TN-S earthing arrangement to the service is liable to fail at any time, and that if the consumer uses it, it's totally at his risk, despite you providing it in the first place.
Don't you think you should be alerting relevant people, and loudly - ie like most of your consumers so they can take appropriate action then.
That's what you may want to happen - I suspect there might just be a bit of an outcry though.
I wonder where the legal people will take the case that results in a fatality due to a failure of your SNE arrangements that couldn't be identified by a consumer or had no warning mechanism in place to identify a potential for that failure.
It'll be an interesting one.
Failure is always an option
 01 May 2013 09:16 PM
Avatar for leckie.
UKPN, sorry for being thick, but do you mean that the dno will not guarantee .35 ohms Ze on a pme system?
Edited: 01 May 2013 at 10:20 PM by leckie
 01 May 2013 09:18 PM
statter
It looks to me like the loss of an earth connection on the sheath of a cable such as an old PILCSTA which ran underground for any distance and typically providing a TN-S supply would be a breach of regulation 13.2 b of the ESQCR. There is a carve out in reg 2 for some older stuff but regulation 13 applies irrespective.
I think it would be reasonable for a DNO to check earthing of these 'metallic screens' from time to time so that any loss of earth connection would be detetected in a timely fashion.
I suspect a court would take a dim view if no inspection regime was in place.
.... so whilst the DNO has no obligation to maintain the connection to a cable sheath it does have an obligation to make sure that sheath is earthed if the cable runs underground.
 01 May 2013 09:25 PM
statter
.......... oh and sorry forgot about 24.4 and 24.5 which require an earth terminal on all new installations and all installations where the service connection is replaced (overhead or underground) irrespective of age, type, location etc.
So if an old service is replaced DNO must make available an earth terminal (prob by TN-C-S) but in some areas this is very difficult (e.g. in rocky conditions with not much topsoil) in which case there is no alternative but to provide a new TN-S earth (or possibly PNB which is TN-C-S anyway) if its the only supply on the transformer.
 01 May 2013 09:37 PM
mikejumper
Imagine if pubic transport operated like that.
'The train on platform 1 is there for your use without obligation but if a wheel flys off at 100mph then bad luck because there is no requirement
for us to maintain our trains'
 01 May 2013 10:01 PM
John Peckham
UKPN
Are you saying that the DNOs are exempt from the Electricity at Work Regulations 1989?
John Peckham
 01 May 2013 10:21 PM
Avatar for leckie.
Blimey, looks like UKPN are on strike! No replies!
 01 May 2013 10:29 PM
statter
I'm not sure that the elec at work regs help that much. IMO they are primarily concerned with ensuring electrical safety at work. It's. Not at all clear that this extends to service cut outs especially if cable sheath is covered and not exposed. The elec at work regs do put an onus on an employer and self employed to make sure installations are properly earthed though.
 01 May 2013 10:32 PM
Zuiko
What appropriate action? To provide safe disconnection during an earth fault? The customer is obligated to do that in the first place!
I don't see the fuss - the consumer should ensure that their installation is correctly connected to earth. If the DNO provide PME then by all means use it, but that does not mean that it is the DNOs responsibility to ensure that the installation is safe and fit for purpose.
DOUGIE1000
Can I ask John have you ever had a pme with a greater than 0.35ohms, I can't ever recall having been on this situation,
Tn-s yes but pme?
Dougie
Power Plus Electrical.co.uk
 01 May 2013 10:34 PM
Zuiko
The .35 ohms is regularly swerved. Let's face it, if the jointer measured 0.4 ohms at the cutout , that's going to be fine. If it starts heading north of 0.5 ohms then the DNO is not going to give you PME.
 01 May 2013 10:36 PM
Avatar for slittle.
I beg to differ with the all knowing UKPN but if a dno provides an SNE earth then they are obilged to maintain it.
It's too late tonight for me to find the words that guide me but I'm sure I can lay my hands on it
And I've had many jobs over the last few years where they have repaired a lost SNE earth
Zuiko
I've come across it hundreds of times. In fact, there was an operational procedure at my old DNO that suggested ignoring up to 0.7.
 01 May 2013 10:40 PM
DOUGIE1000
You as lines man might have come a cross it out on the field as n-e could could be at cableheads and you would be measuring it further away from the cablehead, but at the cable head I can't ever recall getting a high zero on pme.
The cable head is where its joined I guess after all.
Dougie
 01 May 2013 11:19 PM
Zuiko
you see it more in rural areas; the 35mm^2 / 35m rule of thumb is often broken; quite common to see LV tees over 100m with >220V no load at the head and >0.5 ohms ELI
 02 May 2013 12:18 AM
. . . SNE, normally cable sheath, is offered via a clip and earth block on older properties and is there for the consumer to use without obligation on the DNO. The DNO has no obligation to maintain it. . .
I am not convinced about that. The DNO do not have to provide an earth connection to begin with, but if it is provided, then they have to maintain it.
. . . The DNO do not guarantee any external loop impedance, consumers/
designers must decide if the values suit their purpose. . .
That could be interesting too. If the DNO state that their fuse will protect the first 3m of meter tails, then offer a service cable / cutout fuse combination that will not do the job, then I wonder how that would go in court.
 02 May 2013 06:28 AM
Avatar for dbullard.
dbullard
I have a few "in the sticks" PME conversions where the DNO have just taken the CU earth into a set of Henleys on the incoming neutral supply and sealed with their lead crimps, and the overhead supply is quite a long one from the pole mounted transformer about 700 yards away.
I have a PAT testing job coming up soon in one of the property's that has this cobbled together arrangement, and the Ze is almost from memory around .035 or certainly heading that way unless it has been changed since last year
I get the impression that UKPN is a bit of a "Windup" makes a post and runs .................
Daren
edit : fat fingers eating toast and drinking coffee !!!!
www.quest-electrical-sw.co.uk
 02 May 2013 10:08 AM
I understand that 0.35/0.8/21 aren't guarantees, just "usual" upper limits (i.e. good things to base generalised designs on).
What the DNO are obliged to do is ensure that the supply voltage doesn't vary by more than -6% and +10%, which in simple cases, puts a limit on the resistance of their supply lines - they can't start off with more than 253V (as the consumer will get this when the load is zero) and they can't let it drop to less than 216.2V (when the consumer is drawing full load) - a difference of 36.8V. So for a 100A supply the supply L-N impedance can't exceed 36.8V/100A = 0.368 Ohms - and of course in TN-C-S L-N is the same as L-PE, so that's the Ze limit too. For lower loads, the loop impedance could be allowed to be higher.
 02 May 2013 10:19 AM
Avatar for BigRed.
BigRed
Has UKPN being hijacked by David Cockburn? DNO's have to maintain existing earths, pure and simple, why they don't tell the front office guys this is only for their profiteering. Mentionong OFGEM and ESQCR usually gets someone with more than one braincell on the phone....
UKPN, i'm surprised and shopcked at your lack of knowledge of esqcr. Go read a copy before digging holes and jumpng in them.
IET » Wiring and the regulations » The DNO and systems of earthing
