Topic Title: thru crimps
Topic Summary: permanant ?
Created On: 29 April 2013 10:21 PM
Ampman
Got called out to a house were a man had drilled a cable in wall half way up wall .
Temp repair for now .
Options .
Through crimps & tape .
Rewire leg and chop wall ceiling to floor level and try and get chipboard floors up .
Customer don't want box blank plate half way up wall .
Are thru crimps classed as permanant ? Where in regs can u find it ?
 29 April 2013 10:33 PM
Fm
Through crimps are classed as permanant.
Tapes a bit rough though
Terminations should be in an enclosure,many may use heat shrink etc. stagger joins.
 30 April 2013 12:29 AM
SKElectrical
http://www.theiet.org/forums/f...key=y&keyword1=crimps
Ohh don't get Martyn started. I'm anxious every time I have to join a cable since his posts - in fact I don't think I've through crimped since!
I'd use connector blocks but then the OCD in me worries about their ratings of 5A, 15A, 30A , as opposed to nominal 60898 ratings!
If you do joint out in the wall, be sure to wrap with self amalgamating tape, available from screwfix. And then overwrap with insulation tape.
 30 April 2013 07:39 AM
Rulland
If its rfc, can you get to cables above or below, whichever way they run, jb and convert leg to radial-assuming its a dsso that it's feeding.
 30 April 2013 09:16 AM
Through crimps, or solder (better) and heat-shrink and then self-amalgamating tape,
 30 April 2013 02:34 PM
I think they're classed as joints made by compression tool - reg 526.3 (iv).
I'd presume that crimped joints still joints and so subject to 526.5 - so a hole in plaster on a brick wall that's then plastered over probably complies with the non-combustable building materials option of 526.5(iii), but you'd probably need a proper box of some kind in say stud partition wall.
 30 April 2013 10:08 PM
The joint is made by compression so complies. But are they any good? Half the time I find that solid cores do not pass the "tug test". What do the manufacturers say? I bet they say that whether they are solid or stranded, crimps are ok.?
I hope push connectors, wago,etc, prove reliable over time.
Just think, in the 1950's it was pretty normal for cores to be twisted together and wrapped in cloth based insulation tape. OMS told me he remembers it happening.
Joking OMS!
