Topic Title: 2 Things
Created On: 22 April 2013 08:27 PM
frspikeyhead
1. If it is now a requirement that all extractor fans are protected by a 3 amp fuse then why dont the manufacturers incorporate one within it.
2. If the values in tables 41 are for a 0.4s and 5s disconnection times then what values to use on EIC for a TT seeing that it is 0.2 and 1s?
 22 April 2013 08:37 PM
1. Cost I suspect? so they put the ball in our court and make it our responsibility.
2. If on a 30m/a rcd 1667 ohms,
 22 April 2013 08:39 PM
Time, cost and effort I suspect - that and the fact that it won't protect a fractional HP motor anyway.
What TT system have you got that relies on low EFLI to get disconnection - don't you have an RCD to do that job - Table 41.5 etc
 22 April 2013 09:15 PM
prophet
Not all manufacturers require a 3 amp fuse
 23 April 2013 07:27 AM
None of the fans I use for domestic use ask for a 3a fuse.
I use greenwood airvac and vortice. Which of the major manufacturers do require a 3a fuse?
 23 April 2013 08:18 AM
dickllewellyn
Pretty much all the others leckie. I've only recently discovered the greenwood, cracking little units in my opinion, and no 3a fuse requirements!
Richard (Dick)
 23 April 2013 09:14 AM
Well Dick, they are extremely reliable. I used to do a lot of new dwelling, hundreds per year, with several fans in each. In a period of about five years, so approx 1500 fans, I only had to replace 3 under warranty. Not bad eh.
