Topic Title: TPN Disconnector/ fused or not
Created On: 01 April 2013 11:24 AM
dimitar
Hi All, need a bit of advice....
Single phase meter is gonna be replaced by three phase meter in commercial property.
Have already fitted the 3 phase board and prepared the tails for EDF.
I am also planning to install 100 A TPN Isolator between the meter and the DB.
Not sure if its needed to be fused or not ?
Distance is less then 2m as they are in mains cupboard.
DIMITAR
 01 April 2013 11:51 AM
Why would you install an isolator as the board will have a main switch surely ??
If the tails are 2m then no need for fuses, you could ask the metering man nicely and he might fit a REC4 for you.
 01 April 2013 02:05 PM
dimitar
Thanks Stu,
The DB has main switch of course, just had experience before with metering people ,which required isolation after there meter in case DB needs complete isolation .
Dimitar
 01 April 2013 09:30 PM
I'd tell them if I need to isolate the DB then it's a call to the supplier or DNO (depending on the time of day and reasons) to get the cutout fuses removed.
There is nothing in our big green book or indeed the electricity supply regs that says we need to supply a means of isolation between them and us.
 02 April 2013 12:19 AM
rogersmith7671
Quote;
Not really if the distance is less than 2 meters, does the DB have a fused main swich?...some do, so even less need.
 02 April 2013 12:25 PM
jsa986
The fuse is not required as already stated, if the metering people want iso between their supply and your board, get them to do it. No requirements on you for that.
www.icertifi.co.uk
Electrical & Gas Certificates on iPhone & iPad
