Topic Title: Air conditioning
Topic Summary: Thermostat
Created On: 28 March 2013 07:32 PM
Ampman
Evening ,
Any body recommend a thermostat that will switch on temp rise .
Ie i need it to switch on when temp rises above a certain temp to bring on a air con unit .
The thermostat will control a coil on a contactor
Are these stat called change over stats ?
cheers
 28 March 2013 08:55 PM
colinhaggett
Honeywell, yes change over.
 28 March 2013 10:15 PM
Rulland
Refrigeration wholesalers-they'll do various sorts-adjustable diff etc.
 28 March 2013 10:20 PM
briandoherty
Example...Drayton RTS 4?
Brian
 29 March 2013 01:09 PM
M.Joshi
Many digital thermostats such as Sunvic have a wire jumper inside which you cut that makes the relay switch on temperature rise instead of temperature fall. Those thermostats can be used with HVAC systems. I believe the Honeywell digital ones are switched to temperature rise via the installers menu.
 29 March 2013 02:04 PM
GB
Pick a unit with a nice "dead" band if you are installing a heat pump or linking heating into the system.
