Topic Title: Any dialux experts out there?
Created On: 20 March 2013 10:03 PM
peteTLM
Im wanting to do an outdoor car parking arrangement on dialux.
Altough i can muster together a basic room with a few downlights, outdoor flat surfaces which are not dual carriageways or football fields are somewhat non existant on the basic settings or templates.
This isnt a hit and hope thing, its for studies, and has to be within a fine tolerance of lux.
thanks in advance
 20 March 2013 10:06 PM
Pete,
Try Relux, I've not used the outdoor bits but it might be easier.
If I get a chance I'll have a play
 20 March 2013 11:17 PM
mawry
What you need to know Pete?
 20 March 2013 11:32 PM
peteTLM
Well, for a start, how to create the space. The defaults are roads (which the dims wont fit), and sports pitches with the columns around the outside. I seem to struggle really bad with outdoor things on this.
I need to create a flat tarmac outside carpark, with equally geometrically spaced columns with 4 fittings at the top of each.
thanks all.....
 21 March 2013 07:35 AM
alanblaby
Who did this 'training", just so that we can avoid them?
Thanks, Alan.
 21 March 2013 10:07 AM
MHK
Hi Pete,
In terms of free software I would use Relux for lighting calculations as personally I think it is more intuiative and user friendly that Dialux in many applications.
Having used both I would say that Dialux is better at creating 3D rendered images for presentation purposes, however, if you only require a modelling tool to determine lighting levels, back spill etc I would suggest using Relux as it is more simplistic to use with added simplicity that the majority of luminaires can be downloaded through the application rather than requiring the installation of plug-in applications for various lighting manufacturers.
If the application is more critical for say street lighting application for the highways agency etc you may wish to consider a program called lighting reality which is more suitable for this task.
 21 March 2013 06:21 PM
mawry
Pete, if you start from a new exterior scene. One should be there as a default. its a 50 metre hy 50etre squate. You can then add further ground elements to suit and modify the materials(Tarmac, grass, concrete etc) . If you have the layout in a dwg format you can import that and use it to scale the ground element. Then add fittings as above.
Hard to go through a step by step guide on this. You can download the manual(which isn't a great deal of help) from the dialux website.
If you need anything else PM me.
